C554 "Serial himber must be entered ocntact service provider"
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 149
    I have a client with a C554 who states that it was 'unplugged for several days' while they had new carpet installed in their office.
    When they powered it on, it shows the message:
    "Serial number must be entered, contact service provider"
    It won't let me in service mode, and I tried a reset, but no luck.
    From searching the forum it looks like an initialization and firmware update should correct the problem.... is that correct?
    Thanks for any help!
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5849
    not even an "e" model?
    the battery is dead.
    its also discontinued i believe so its time for an upgrade.
    if you want to try and change the battery good luck.
    • FuserNoob
      Service Mgr, CISSP
      • Jul 2022
      • 149
      That was my thought...on both counts
      Thanks!
      • aberock
        • May 2022
        • 124
        replace 3v battery
          • 8176
          You could try updating the firmware, noting to loose.
          www.printerfirmware.co.uk
          • FuserNoob
            Service Mgr, CISSP
            • Jul 2022
            • 149
            Yeah, I was going to give that a shot, along with replacing the battery.
            On that note.... Anyone know where it is?? And the part #?
            Thanks 😉
            • adecanmin
              • Oct 2010
              • 317
              Thanks 😉
              I got mine from digikey. I can get you the part #if you're not able to find it.
              • FuserNoob
                Service Mgr, CISSP
                • Jul 2022
                • 149
                I'd appreciate that, One Stop doesn't have the C554 manual any longer...
                UPDATE:
                It IS a C554e
                • Synthohol
                  • Mar 2016
                  • 5849
                  i sent you some "stuff" via PM
                  • FuserNoob
                    Service Mgr, CISSP
                    • Jul 2022
                    • 149
                    got it, THANKS!!
                    • DK-tech
                      • Apr 2021
                      • 25
                      I have had many of these. The battery is dead an ALL data is gone, so you have to resolder a new battery to the MFPB AND put in new SSD board. Then it needs 96-layer bootrom, firmware unpacking-setup ect. Unless you are a KM tech I would not advise you to attempt yourself though.
                      • FuserNoob
                        Service Mgr, CISSP
                        • Jul 2022
                        • 149
                        you had me at 'solder', thanks for the pep talk 😁
