Swapping Biz "8" series MFP boards??
  • copyman
    Owner / Technician
    • Sep 2005
    • 4654
    Has anyone swapped MFP boards between "8" series with success? I have a C258 and want to swap MFP from a C308.Are the eMMC & 2 eproms transferred from original board to donor board? Thanks
  • Albonline
    • Sep 2008
    • 1147
    If they are the same board (look the same) a couple small chips at the bottom edge. and wipe it of course. set machine type and flash it.
    • Synthohol
      Certified Konica Expert
      • 5809
      same part number. go for it.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4654
        Ok so here is update. Swapped out the boards. Moved over the 2 small chips & eMMC to donor board. Changed machine type. First it came up with "invalid external memory" but after doing logical format on HDD it booted up and is now working good! Thanks again for all the help.
        • rrrohan
          • Sep 2011
          • 1977
          assuming you lost the meter counts though?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4654
            All counters good same as they were before the swap. Only 5k on this off lease machine. The low meter makes me think this machine sat for a while with a bad MFP.
            I thought the reason why you move the the eMMC and 2 eproms from original MFP to donor was to carry over all the machine info, i.e meter counts, serial #'s, consumables, mac address, etc. Which it did move everything over in my case.
            • Albonline
              • Sep 2008
              • 1147
              the ifo is on the emcc and the small caterpillar chips.
              • Albonline
                • Sep 2008
                • 1147
                i forgot about part the system code being on the hdd on these.
