hello guys . customer c250i having this issue . is it the fuser unit problem . i did change lower pressure roller and sleeve . still having this issue . any solution ?
kmb c250i toner can be rub off
You can try workaround FW G00-Q8 (or later) + Engine DipSW 43 Temp +5/+10°C.
I have to ask an obvious question: What kind of media is it (gsm), and what is the tray set to? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=👍 1Comment
