C450i image quality issue
  • barber782
    • Aug 2011
    • 286
    Greetings everyone,
    This morning we've had a C450i with some strange watermark like effects (black only) appear on the page.
    Machine has done around 300k and have replaced the black drum to see if it cures this problem.
    Unfortunately it hasn't made a difference. From the samples I have, the marks appear to be the same distanced apart as a drum circumference.
    Has anyone had one like this?
    Have a great day.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4724
    I know you posted black only but did you pull transfer belt out and look to see if any marks on it. If transfer belt was bad it should show on all colors but I would still look at belt.
    • barber782
      • Aug 2011
      • 286
      @copyman -
      Yes they removed the transfer belt assembly and inspected it. It does look a bit like when people try cleaning the belt leaving a residue, but not the case here.
      I did notice on the left margin directly inline with the marks there is an indentation.
      • tsbservice
        Field tech
        • 8021
        Originally posted by barber782
        ..the marks appear to be the same distanced apart as a drum circumference.
        What is the distance - 94mm?
        • barber782
          • Aug 2011
          • 286
          Sorry the technician forgot to mention that its actually feeding long edge 😅😅
          • Synthohol
            Certified Konica Expert
            • 5849
            so that sample is letter\a4 size?
            • Sencho
              • Feb 2023
              • 21
              Have you tried with another developer unit? This problem can occur when the developer unit is near the end or if replacement toners are used. I think replacing the developer unit will be the solution.
