Super lurker
  • Overlord
    • Sep 2021
    • 3
    [Misc] Super lurker
    Run a computer repair shop. have only touched a major printer from time to time. like paper rollers. figuring out jam workarounds. ya know basic.
    Picked up a bizhub c452 with finisher. contacted service who held the account can't guarantee me they will get it working. so meh.
    got it. it was jamming at the paper passage i believe is the position. below scanner above toner the rollers taking it to the finisher. realized the rollers were connected to the finisher so i hooked it up. BOOM full stop system will no longer print gets stuck in printwait on the job. no error codes no nothing. i have torn this machine apart looking for lose connection's. dead wires almost every suggestion on here. but i can not seem to find any situation like this on the forum with a finisher attached.
    This baby prints so good if i remove the transporter and finisher and let it flop. but i picked this unit up so i could provide free business services in the front of my shop for new startups. I have 4 work station's and provide free mentorship to any who need it. so i was geeked when i could pick one of these up on the cheap and try to get it working at full tilt.
    the system doesn't have the animated guide data anymore attempted to get it unsuccessful i have no idea where to go from here. none of the service checks work on the finisher. just kinda dead in the water. But she does print without fail i need to replace the 3 and 4 paper tray rollers for sure. but once it gets going it never fails.
    Would apricate any guidance thanks.
  • Synthohol
    Certified Konica Expert
    • 5702
    Re: Super lurker
    sent you a PM
    thanks for being a contributor!
    • Zesti
      • Jun 2009
      • 308
      Re: Super lurker
      I love the C652 series machines,,, really a workhorse..... especially when found in give away ....
      It's finishers are a pain in neck.... Just remove it and try get the receiving tray and it will run like a Gem... Good luck.
      • Overlord
        • Sep 2021
        • 3
        • femaster
          • May 2011
          • 1458
          Re: Super lurker
          With the finisher connected, powering up the whole system, does it come up to READY, or do you get some sort of service code that shows up? If Ready, and you open the door on the finisher, does the system indicate that the door is open and ask you to close it?
          If you try a basic single page copy job, do you get any codes then, besides the status message PRINT, WAIT?
          • Overlord
            • Sep 2021
            • 3
            Re: Super lurker
            Yes I can start any type of job but with the finisher connected the system holds everything with printwait. No error codes and yes If I open the finishers side door it's indicated and once I close it. It spins up and continues to do nothing. No errors.
