PC-417 Slicing Paper
  • AlaskaCopyTech
    • Jan 2024
    • 78
    Hello all,
    This one has stumped me. Tray 3 of a PC-417 is slicing paper. I caught it in action and it was cut before the horizontal movement section.
    • 23008
    Do you have a photo?
    • AlaskaCopyTech
      • Jan 2024
      • 78
      This gallery has 1 photos.
      • AlaskaCopyTech
        • Jan 2024
        • 78
        • kingarthur
          • 1358
          Really silly question - have you taken the paper out of the tray and examined it,I had a problem once, where from only 1 tray, they were complaining that print had a "cyan haze" across it. Discovered this tray was where they had there headed paper, their heading was cyan - the printers had given them a very bad batch of printed headed paper - it wasn't the machine
          • Tech09
            • Apr 2020
            • 145
            I've had flawed paper do that before. It is awfully strange how your paper is ripping though.
            • AlaskaCopyTech
              • Jan 2024
              • 78
              Current troubleshooting steps:
              1. Check to make sure paper is goood - all xerox vitality paper.
              2. Remove tray 3 paper feed assy upper and deburr material.
              Currently paper is jamming in the fuser and asking if it's the right size.
              I haven't tried different size paper because I don't have a4 on hand and I don't know how you would load anything else in a 417 without jamming it.
                • 23008
                Along these lines, I've had customers tell me about wrinkles, rips, discolorations, even random printed images on the second side of the paper when printing simplex. All these situations originated in the paper tray with damaged or pre-printed paper. The cut looks way too clean to have been done by the machine. The copier would have produced a ragged tear. If you cannot reproduce the problem, I would take a ream of paper, run it all, then shrug. Eventually somebody will open a new ream of paper and the top sheet will be cut. " ... hmmmm! I wonder if it's the paper??" =^..^=
                • kingarthur
                  • 1358
                  I'm assuming, that if the machine is cutting the paper, the missing part of the page is in the machine somewhere....if it's not, then it's definitely not the machine
