Konica minolta bizhub C3350 Airprint cant be enabled
  • Brejvi
    • Aug 2021
    • 6
    Hello everyone,
    Iam having issue with my KM bizhub C3350, iam trying to enable Airprint. I already set software switch 168 to HEX00, and tried to enable Airprint in network setting, after machine restart airprint is not enabled. I cant enable Bonjour either.
    I installed firmware controller fw - A3GN30G0851-899 controller fw - A3GN30GD883-W51 engine fw - A3GN0Y00050G002100 and it still does not work
    Do you have any ideos what i should do next?
    Thank you
  • kingarthur
    • 1390
    Re: Konica minolta bizhub C3350 Airprint cant be enabled
    You'll probably need the Aiprint activation code from Konicaminolta
    • Brejvi
      • Aug 2021
      • 6
      Okay, thank you. I will contant them.
      • Synthohol
        Certified Konica Expert
        • 5908
        heres a few other solutions to airprint problems.
        Problem
        AirPrint not working properly after updating to SMB 2.0 firmware.
        Solution
        CAUSE: Controller firmware requires updating.
        SOLUTION: Install firmware version A3GN30GJ8C3-W51 or newer. The latest version firmware is available for download via One Stop Product Support.
        Problem
        AirPrint (Bonjour) setting is disabled
        Solution
        CAUSE: Firmware requires updating
        SOLUTION: Install the following firmware based on the model. The latest version of firmware, system software or drivers is available via One Stop Product Support.
        • bizhub C3110; A6DT30GJD01-951
        • bizhub C3100P: A6DR30GJD01-951
        • bizhub C3850/3350/3850FS; A3GN30GJ8C3-W51
        Problem
        PROBLEM: AirPrint button is not available.
        Solution
        CAUSE: Incorrect software switch settings
        SOLUTION: Perform the following procedure:
        1. Enter Service Mode
        2. Select System 2
        3. Select Software Switch Settings
        4. Select Sw 13
        5. Change setting to HEX 04, press OK and select Fix
        6. Cycle the power on the machine and now the AirPrint button should be available to select
        • Brejvi
          • Aug 2021
          • 6
          Thank you very much sir,
          Firmware version A3GN30GJ8C3-W51 should solve my problem, but i cant download on KM download center, because their download link is broken somehow. Any ideas where can i download this specific version of firmware?
          • kingarthur
            • 1390
            apologies, I thought you were talking about the C3350i, the C3350 is an old piece of kit
            • Brejvi
              • Aug 2021
              • 6
              Never mind, thanks for your effort anyway. :-)
              • Brejvi
                • Aug 2021
                • 6
                Installed controller version A3GN30GJ8C3-W51. And it did not help. Still can't enable bonjour and airprint.
                • ionutzd
                  • Jan 2022
                  • 2
                  Hi,
                  where did you get the new firmware? I'm trying to find one since november
                  • copier tech
                    • 8222
                    Originally posted by ionutzd
                    Hi,
                    Happy to help.
                    Printer & Copier Firmware - www.printerfirmware.co.uk
