c458 white spots on print
  • Carlos Rego
    • Mar 2024
    • 40
    Hi guys
    Shadows or white spots appear on the prints . what may it be ?
  • Cantechman
    • Nov 2008
    • 228
    Originally posted by Carlos Rego
    Hi guys
    Did you do test prints for each color in service mode? It's probably a worn out black drum but color test prints of each color should help narrow it down.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4713
      If it's happening on all colors I would suspect transfer belt. What are consumable life counters? If just one color then look at drum, dev unit. Also aftermarket toner can cause some weird issues like that.
        • 23009
        Try these test patterns:
        Personally, I think you'll find the cyan developer de-toned.
        • Reed
          • Feb 2011
          • 258
          The drums fixed that issue for me.
          • Carlos Rego
            • Mar 2024
            • 40
            All four drums are new
            • Carlos Rego
              • Mar 2024
              • 40
              Mean time made some test prints and results are on file,also reprinted a work I had on a thicker paper and again,the spots appear
                • 23009
                Are you setting the correct media type? I think not.
                • Carlos Rego
                  • Mar 2024
                  • 40
                  Media settings are correct
