Yellow streaks. minolta C258
  • myster
    • Oct 2011
    • 79
    The customer was complaining about yellow streaks.
    We have changed the yellow drum for a compatible one, and random stripes continue to appear on different pages.
    Any possible solution? Is the drum bad?
    Why do compatible drums work so poorly on series 8 machines?
    Thank you so much
  • Gaffers01
    • May 2011
    • 335
    Looks like a similar distance to the charge roller, did you replace it when you replaced the drum?
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5824
      looks like charge roller has a flat spot to me. swap it with magenta, see if it follows drum or stays with DV unit.
      • tsbservice
        Field tech
        • 8013
        Easy 😄
        • myster
          • Oct 2011
          • 79
          The drum unit was completely replaced with a compatible one.
          We are awaiting the exchange for an original one. What seemed strange to me is that both the one we removed and the compatible one gave the same type of error.
          • Synthohol
            • Mar 2016
            • 5824
            have you tried the drum in another color slot? kinda an important question.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4700
              Why not try the suggestion by Synthohol. That is some great free advice. If you would of tried swapping drums btween colors to see it was a defective aftermarket drum you wouldn't of needed to even post here.
              • myster
                • Oct 2011
                • 79
                Basically because I'm not in the client.
                The customer complains about scratches, we go and change the drum unit, the machine works perfectly, a day later the customer complains about the same problem again.
                I ask on the forum to get help on other possible causes of the failure.
                We have returned to the customer with an original drum unit, so far, 7 days of perfect work.
                Thank you all
                • myster
                  • Oct 2011
                  • 79
                  Hello
                  2 weeks later the customer reported again that the problem had reappeared, with a new original drum.
                  We have reconnected the all laser connectors and the data bus. The machine works perfectly again. I cross my fingers every day
                  thanks
