C308 spots?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    C308 spots?
    Hi,
    Anyone ever see a halftone test sheet like the attached? Only happening on black halftone test, CYM are fine. Tried new K drum didn't help. Developer is good and not depeleted. Regular color & mono prints look ok. Thanks in advance
  • KMFLT3CH
    • May 2017
    • 241
    Looks like K dev unit has been contaminated with bad, likely knockoff toner.
    edit: check the end cap on the toner bottle if it's sharktooth/wavy - I've had a lot of issues with those.
    • Synthohol
      Certified Konica Expert
      • 5846
      to me looks like the 1st transfer roller for black fell out of its little holder inside the belt and not enough pressure on one side?
      • copyman
        Owner / Technician
        • Sep 2005
        • 4718
        Thanks for the replies, I was going to return with a K dev unit and transfer belt. What's weird is the demo page and regular prints are fine.
        • tsbservice
          Field tech
          • 8020
          +1 for bad toner. What's K tcr value?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4718
            Genuine toner, all tcr values within range, around 6.5
            • Hansoon
              • Sep 2007
              • 3389
              You said you already changed the drum, but it looks very similar to what I had a month ago with a BH-C-280, and it turned out to be the K-drum.
              Hans
              • copyTcat
                Senior Technician
                • Apr 2015
                • 58
                check if drum has any grounding issues. wqas this issue also on the old drum you removed?
