Bizhub 215 firmware
  • micho
    • Nov 2024
    • 8
    Bizhub 215 firmware
    I am experiencing an issue with the network card on my bizhub 215. The printer recognizes the network card (NIC FW ver A3PE0YO-5000-GC3-01), but when I connect the LAN cable, none of the lights on the network card illuminate. I would appreciate it if you could provide me with the necessary firmware to resolve this problem.
    And Main FW was A3PE0Y0-0100-G03-02 and i found A3PE0Y0-0100-G02-12. its downgrade or? Can someone give me newer F/W?
    boot rom 00000Y0-01E0-g01-00
    engine A3PE0Y0-5000-G00-07
  • Duplicator
    • May 2022
    • 246
    Are you sure that's a firmware issue? Do other Konicas work if you connect them to that cable? If you have no lights at all you may have bad wiring or a bad switch port on the other end. Generally Konicas do not have Auto-MDIX so if the wiring is a bit off they won't get a link where some computers will.
    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
    If I helped you out, please give me a thumbs up! It helps my reputation.
    • micho
      • Nov 2024
      • 8
      I wanna update all firmware-s , to eliminate problem in them. Without LAN connection i can't set up time thru MENU on printer.
      WIRING - you mean crossover or straight through RJ45 ?
      • Duplicator
        • May 2022
        • 246
        Yeah. I'm saying it is possible that pins 1 thru 8 on that cable may not be connected correctly or you may have a problem with the device on the other end. Have you tried a different cable?
          • 8164
          We can supply the firmware should you want to give an update a try. Drop us an email.
          www.printerfirmware.co.uk
          • micho
            • Nov 2024
            • 8
            I tried with different cable. Same thing. I change network switch, same thing.
            • micho
              • Nov 2024
              • 8
              Sorry for the inconvenience. Can you give me a diagram of the cable that connects the printer? For now, I've tried these options.
              And this is network card in printer. Thanks.
              • micho
                • Nov 2024
                • 8
                Please, can someone send me firmware Main FW was A3PE0Y0-0100-G03-02 or newer. please. old behave strange.
                • Duplicator
                  • May 2022
                  • 246
                  Unless you are plugging this directly into a computer you do not want to use a cross over cable. You want to use a straight through cable. It will either be TIA-A or TIA-B. Both are in the image below.
                  • micho
                    • Nov 2024
                    • 8
                    Nothing. No light from Leds on connector where i plug cable. Only when i power off and power on printer. Leds one time blinks and that is that.
