Bizhub C750i C-D010
  • Nikko Shimol
    • Nov 2024
    • 2
    [Error Code] Bizhub C750i C-D010
    Problem: There was an unexpected power outage, which resulted in the device displaying the error code C-D010.
    I'm unable to go into the service mode the normal way. The counter screen won't come up.
    I need fo flash? If yes how to get the file and hot to enter in service mode?
  • Ziggy
    • Feb 2018
    • 695
    The power outage could have unset the storage board. Hold down the little button on the back of the control panel while powering on the machine . When you see trouble reset DONT push it, Instead use keypad to enter service mode and go to system 2 and set storage type to Storage not micro sd.
    If it is already set to storage the you will need to format and maybe replace the storage board
    • Nikko Shimol
      • Nov 2024
      • 2
      Thank Markks, it's done. I formated the storage.
      • tsbservice
        Field tech
        • 7986
        And?!?
