C3350i - sleep mode -fan
  • Duplicator
    • May 2022
    • 245
    #16
    There is a dip switch that controls the fan on the newer firmwares for the A4 i-Series. The info from Konica talks about CPU over heats.
    • C5372 (CPU temperature failure) occurs during the low power or the sleep mode.
      As a countermeasure, please change software SW to work the FAN at full speed during Low Power and Sleep mode after applying this firmware.
      A function to work the CPU FAN at full speed during low power and sleep mode.
      Software SW No. 159 (bit7)
      Hex: 00 (Disable [default]) FAN works at half speed in low power/sleep mode.
      Hex: 80 (Enable) FAN works at full speed in low power/sleep mode.
      If the FAN is working at full speed, it can be noisy. So, please get customer's permission before CE changes the fan speed.
    Like tsbservice said It's probably a good idea to just live with the loud fan on an A4 machine. The CPU boards are a common failure on the latest generation of Konicas. They are not cheap and probably not something you want to take on without access to all the dealer tools. There is probably a way to replace it with a Noctua although I've never tried.
    The airflow on the A4 machines is so terrible that I have seen people cut large sections out of the metal plate under the rear plastic cover to help the fan cool the CPU better. I'm not sure I would recommend that but it has been done.....
    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
    If I helped you out, please give me a thumbs up! It helps my reputation.
    • kasperek
      • Dec 2024
      • 12
      #17
      The problem is that it is constantly sending packets in sleep mode, which causes the processor to work and the cooling to turn on. Does it have to constantly send something?
      • tsbservice
        Field tech
        • 8013
        #18
        Go in admin mode and in network turn off all protocols you can IPv6, FTP, etc. just leave only essentials for your own needs. Hopefully that will stop broadcasting network and you will be happy πŸ˜€
        P.S. I tend to leave endusers not ruining their machines but there are few cases when educated people deserve guidance and that may be true in your case.
        • Duplicator
          • May 2022
          • 245
          #19
          As far as network packets go and hidden settings...
          Have you tried disabling usage reporting in service mode?
          System 2 -> Acquiring Settings -> Usage Frequency/Collection Settings: Off
          Also I would check in service mode:
          Network Settings -> Function Setting -> Enable Settings: Disable
          If vcare was somehow enabled I would verify that is also set to 0.0.0.0 or whatever the default value they use to disable it is.
          • kasperek
            • Dec 2024
            • 12
            #20
            I'll start working on the service menu in a moment
            • kasperek
              • Dec 2024
              • 12
              #21
              I turned off both features and it is much much better. It turns on for a few seconds, at least after 10 minutes πŸ˜€
              igmp packages cause this
              • mascan42
                • Oct 2008
                • 484
                #22
                What firmware is it running? There was an issue with Goo-RB firmware that the fan was shut off during sleep mode to make it quieter, but it caused overheating issues because passive ventilation wasn't good enough. GG1-RB special firmware solved that problem.
                • kasperek
                  • Dec 2024
                  • 12
                  #23
                  GG2-RE(00)
                  Sleep mode should be silent and wait for a signal from the network to wake up. In this state there is no need to send packets and it still communicates multicast. It should be the same as via USB or should be changed to efficient passive cooling for network operation in sleep mode. KM failed with this option
                  • Pandabeest
                    • Nov 2016
                    • 5
                    #24
                    Here in Europe there is an other mainboard available with 2 different resistors so the fan doesn't turn on. It's a designflaw on the board. Not a setting and/or software issue.
                    • elmaligno
                      Expert technician KM
                      • Oct 2009
                      • 302
                      #25
                      SW189 hex 80, itΒ΄s all. FW G00-RD and later A4 colour, GG1-RB and later A4 BW
                      Field technician since 1994
