Bizhub C258 artefacts, strange lines on printouts
  • Takhnamishvili
    • Mar 2019
    • 53
    Hello guys.
    Bizhub C258 prints very strange black lines.
    Swapping PH unit + PH unit control board did not help;
    Swapping FRSB did not help;
    Swapping High Voltage Unit did not help;
    Swapping MFPB did not help.
    Machine has only 80K clicks on counter, spare parts life are about 50%, consumables are genuine.
    Any suggestions will be highly appreaciated.
    Check attachment. It's printed from service mode, with 0 bit black. Zoom it in for better visual understanding.
    • 23010
    Re: Bizhub C258 artefacts, strange lines on printouts
    Those would have been my choices.
    Do you get any of the original image?
    Is this a background behind the text?
    Was the sample a black-only scan, or a color scan? I suspect it's a black scan since there are no color pixels that I can identify. I would expect to see a couple color pixels ... even if the defect is black only.
    Was this page fed LEF or SEF? If it was SEF, I would try the primary charge roller first (black drum unit assy).
      So many questions... so little info. [emoji1]
      • byronf
        Senior Member
        • Sep 2017
        • 109
        Originally posted by Takhnamishvili
        Hello guys.
        Hi,
        This seems to be your drum unit, 80k these charge rollers start failing. Change your drum K.
        • tmmdmmm
          • Apr 2021
          • 173
          Hello guys.
          I've only ever seen this once, on an i series with a drum at 40k clicks. Back before we carried the i series drums in our stock, was more of a headache to troubleshoot than I care admit. I'd say 100% drum
          • copier tech
            • 8186
            Hello guys.
            I assume before you replaced all these boards you did swap the black IU & transfer units first or at least remove & look to see it the blades are cleaning?
            • Takhnamishvili
              • Mar 2019
              • 53
              I have not any of the original image, this phenomenon appears only on BW prints. On color printouts there are different vertical lines.
              Yes, the sample is black only scan. Page is fed LEF. If the black drum is faulty, does it mean that I have to change it with new one? because I have already swapped Black drum unit with good working one, it gave nothing, changed black developer unit with NEW one and it gave nothing too.
              • Gift
                • Mar 2011
                • 2459
                Have you tried and clear all memory via in SP? (do a USB backup first)
                Usually I'd also say it looks related to the stuff you already swapped - perhaps you should really go with a new drum unit just in case.
                If you print in color you say it looks different? Are there still black lines or also color lines visible?
                We also had case kind of looking like this caused by the PH assy - we circled all around the problem because the image defect didn't appear "digital" to us. But you already ruled that one out...
                • Takhnamishvili
                  • Mar 2019
                  • 53
                  Thank you for your answer.
                  When print in color, there are black lines but shape of them are straight, not as wavy as you can see in attachment.
                  One question, what means SP?
                  • Gift
                    • Mar 2011
                    • 2459
                    service program
                      • 23010
                      How about internal prints, like the management list or configuration page? Do you get any of the original image?
                      If you emergency stop the machine mid-print, is there a properly developed latent image on the belt? I'm thinking probably not. Is there a properly developed latent image on the black drum? If yes, perhaps there is a primary transfer charge issue.
                      Can you cheat the waste bottle sensors, and see if the black drum is rotating? If the black developer or drum were not rotating you might get an image like this. Or if the laser was not writing the image ... but you've replaced the laser.
                      Just speculating. Maybe this will start you in another direction. =^..^=
                      • Takhnamishvili
                        • Mar 2019
                        • 53
                        Many many thanks for your advices. I will try these steps and will be back with results
                        • tsbservice
                          Field tech
                          • 8028
                          Change black drum with new. Your Vpp voltages are trown off. That's why you put another used but good working drum change nothing. New drum with new chip will register correct voltages especially Vpp which in your case may be under 1000, see table 1 those values mean something
                          • Takhnamishvili
                            • Mar 2019
                            • 53
                            All Vpps are above 1000
                            • tsbservice
                              Field tech
                              • 8028
                              How much above? Post screenshots.
