Bizhub C258 artefacts, strange lines on printouts
  • FrohnB
    • Jul 2017
    • 1919
    #16
    Re: Bizhub C258 artefacts, strange lines on printouts
    Have you tried a different Transfer roller?
    Omertà
    • Takhnamishvili
      • Mar 2019
      • 53
      #17
      Guys, I solved this issue by increasing Vpp-K value. Image became perfect. Thank to all of you and especially to tsbservice! Solution is temporary, customer will change black drum with new one after few days.
      • tsbservice
        Field tech
        • 7999
        #18
        Glad you sorted it.
        Actually those guys who advice to change black drum save the day
        • Takhnamishvili
          • Mar 2019
          • 53
          #19
          Glad you sorted it.
          Yep, black drum failed, as guys mentioned and advised to change it. But I learned how to solve it temporary, earlier I have never touched Vpp values, did not know anything about them😁
          • Gift
            • Mar 2011
            • 2459
            #20
            Glad you sorted it.
            Still interesting, I never really fiddled round with KM voltages, too so I'll keep that one in mind and thx for that hint.
            • copier tech
              • 8133
              #21
              You changed all those parts for a simple drum issue?
              • Takhnamishvili
                • Mar 2019
                • 53
                #22
                Yes
                • rjjr148
                  • Jan 2023
                  • 8
                  #23
                  Bizhub C308 stranges lines appear on print in color & bw.
                  Any suggestions will be highly appreaciated.
                  • Synthohol
                    Certified Konica Expert
                    • 5808
                    #24
                    feed direction?
                      • 23002
                      #25
                      Those color bars have to be crossfeed. One of your drums is arcing to it's developing unit. Usually it's the one with the faintest color bar, so judging from your samples it's either yellow or magenta. Replace the drum and developer units of the desired color together at the same time.
