BH-C-284e, rookie question....
  • Synthohol
    Certified Konica Expert
    • 5842
    #16
    Re: BH-C-284e, rookie question....
    when you select admin mode you have 2 choices enter encryption code or format right?
    im only suggesting to choose format.
    ive had a bunch of lease returns and once thats solved he can move on to the next stage.
    yes, Hansoon is a cool dude, ive helped him before
    • rrrohan
      • Sep 2011
      • 1977
      #17
      Ive accidentally bypassed the password screen in the past when i unplugged a fax kit without disabling it first.
      so i went into service mode and as it got to password screen it c coded. i think open and close front door and somehow i was in without needing the password.
      • avecosat
        • Jun 2012
        • 305
        #18
        I don't know if it will help but machines coming from Germany sometimes changed the admin numbers using the serial number of the machine. I don't remember it well but I think it was the last 8 serial numbers
        • Hansoon
          • Sep 2007
          • 3386
          #19
          Re: BH-C-284e, rookie question.... Partially solved.
          Guys, I got finally from a working machine the HD and all my machines are tested working with that single drive and not giving the encryption error indication anymore. Only problem left are the unknown admins codes but will find that out later on.
          Lots of thanks to you all for being with me in this matter. I just made another contribution to support this great panel and its fine members.
          Hans
          • Gift
            • Mar 2011
            • 2459
            #20
            Lots of thanks to you all for being with me in this matter. I just made a contribution to support this great panel and its fine members.
            Hans
            Hope you can figure out the origin of these units. I know that some dealers and KM direct marketing do cutomize the password - in most cases the solution is just a phonecall away.
            • tsbservice
              Field tech
              • 8020
              #21
              Admin password isn't a problem to change with access to service menu(CE mode).
              • copier tech
                • 8165
                #22
                Hans
                Glad you got them going.
                You can simply reset the admin password from CE mode.
                • Zesti
                  • Jun 2009
                  • 308
                  #23
                  Hans
                  Just reset NVRAM and apply appropriate FW's and movie data later for admin or service mode passwords. As far as the HHD password just enter 123........ as far it goes and new password will be set.
                  • Gift
                    • Mar 2011
                    • 2459
                    #24
                    ah ok - thought it was about access to the service menu, guess I gave it a too quickly read here
