bizhub 458e touch panel lock
  • Francisco37
    • May 2019
    • 5
    Hello everyone, good morning
    I would like to ask if anyone has had this problem.
    When I turn on my Buizhub 458e the touch panel does not respond, the off keys do but the touch pad does not respond.
    I don't know if it has to do with the firmware, this is the one I have F000-GC1-V8
  • doinbox
    • Jan 2013
    • 89
    Sounds like the Touch screen Digitizer has packed in.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4618
      You can try updating firmware but possible the touch screen is bad.
      GC1-V8 is special firmware from 2020. The latest regular base firmware is FW AA6R0Y0-F000-GCR-Y2 from 07/24
      • Francisco37
        • May 2019
        • 5
        Good morning.
        Thank you very much for the answers.
        Regarding the first one, it was the first thing I tried, I exchanged it for another panel and it remained the same.
        Regarding the second one, thank you very much, I'm going to try it and I'll tell you in a few days.
        • Oystercopy
          • Oct 2009
          • 623
          I've had a few of these 8 series, mostly the C-458s for some reason, do the same thing. It ends up being a bad hard drive. It usually starts by the customer having to turn the machine off and on repeatedly for the screen to start responding. Then it will stop altogether.
          OC
          • copyman
            Owner / Technician
            • Sep 2005
            • 4618
            There is also a reset/recovery firmware you could try if HDD is ok. Please consider making a small donation to this website. Best of luck
            • Francisco37
              • May 2019
              • 5
              Hello good morning.
              For now it seems to be working with the firmware I tried but the HDD thing has its logic so if it fails again I will go down that path.
              Thank you all very much
