Getting into Administraton while C code is active on C554e
  • printajsifajl
    • Jul 2024
    • 40
    We have a machine that has C code right now. Trouble reset doesn't clear it so we want to backup the machine to USB and transfer everything to different machine.
    Is there any way to circumvent the limit of Utility menu showing only Device information and Consumable Life buttons. Web page backup is avaliable but Konica we want to backup to is 558e
    Thanks for the answers.
  • astanbr85
    • Jul 2017
    • 2
    What C code is it you have? It might be that with the code you've got, an export isn't available anyway
    • printajsifajl
      • Jul 2024
      • 40
      It's c-3102. But I'm asking even generally cause it blocks this if you have for example open doors of the machine.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4756
        You should be able to enter service mode but may take a few mins before showing up. Also could leave front door open and enter service mode. Or as last resort hold down yellow reset while turning on and trouble reset for code. You can also enter service mode this way.
        Added: Some good advice from Synthohol, I missed you were asking about entering admin mode. Was just thinking about clearing the code.
        • Synthohol
          Certified Konica Expert
          • 5888
          are you able to access it via web? you can backup the addy book and other settings there.
          bit of a pill to edit the xml file with excel but maybe the pagescope data administrator will do the transfer for you?
          • printajsifajl
            • Jul 2024
            • 40
            Yeah, that will be the route we will go through - With Data administrator, but I was wondering if there is an option to get into administrator menu when jam or c code is present.
            • tsbservice
              Field tech
              • 8049
              I'm sorry to say that but Konica Minolta softwares are shite, every time I played with one of them I ended up with a lot of wasted time. Better stay away from them get job done... somehow and move on.
              • printajsifajl
                • Jul 2024
                • 40
                Yeah, we have Data Administrator is crashing on few laptops. But it was invaluable when it was working. 😀
