Name of itens Minolta
  • andrecopfac
    • Feb 2020
    • 17
    What is the name of the foams used in the seals of the waste box and cleaning blade ?
    • 23008
    Re: Name of itens Minolta
    I suppose that I would call them "cleaning unit seals", but depending on the model, they may not be available as individual parts.
    What model did you have in mind? =^..^=
    • andrecopfac
      • Feb 2020
      • 17
      • lartis.aineias
        • 78
        We are technician not chemist [emoji23]
        Στάλθηκε από το AC2003 μου χρησιμοποιώντας Tapatalk
        • Synthohol
          Certified Konica Expert
          • 5824
          Foam pads are foam pads.
          [edit] you can buy sheets of foam, cut to size and use nito tape or upholstery adhesive spray. [/edit]
