Strange Scan Mode
  • Duplicator
    • May 2022
    • 246
    Strange Scan Mode
    Hello everyone.
    I have an odd problem. When my customer enters the scan/fax mode they get this screen. Hitting exit returns them to the regular scan/fax mode. I've tried searching the service manual for "Scan2Workstation" with no results. I've also tried Googling it. My only guess is somebody installed an app onto the copier. Has anyone seen this before and know what it is?
    Edit, sorry forgot the model. It's a Bizhub 360i.
    Last edited by Duplicator; 01-15-2025, 06:50 PM. Reason: Forgot model. Include model information.
    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
    If I helped you out, please give me a thumbs up! It helps my reputation.
  • Slammers
    • Feb 2019
    • 136
    That is a weird one indeed. It does look like there is an app running from the "Application Extended Setting" message you can see at the top.
    Have you checked under Web Connection - [Network] - [OpenAPI Setting] - [Specified Application Start Setting] to see if there are any apps tied to the launch of the scan/fax function?
    • Duplicator
      • May 2022
      • 246
      I have not. I don't have remote access to the machine and I don't have a contact from their org onsite at the moment. That is a good idea, I will check that once I have access to the copier.
      • tsbservice
        Field tech
        • 8020
        100% this is third party App installed.
        • Synthohol
          Certified Konica Expert
          • 5842
          id touch application, de-select whatever is highlighted and save as the default.
          may be a selection to use default.
          • Oystercopy
            • Oct 2009
            • 623
            Or you might have to do an Initialization, which should get rid of whatever the last end user (or IT person) programmed in it?
            • Synthohol
              • 5842
              you will have to reactivate the HDD and load movie data if you initialize it.
              just saying be prepared.
              • Duplicator
                • May 2022
                • 246
                Hello everyone. Just wanted to update this thread with the final resolution.
                I was unable to find a setting at "Web Connection - [Network] - [OpenAPI Setting] - [Specified Application Start Setting]" that had any influence on the copier's behavior.
                However, I did find a table of apps at "Utility -> Administrator -> Store Address -> Application Registration". Deleted the only registered app and the weird screen went away.
