bizhub 4050i J92-01
  • tsbservice
    Field tech
    • 8051
    bizhub 4050i J92-01
    Lightly used almost as new machine, jam only in duplex mode randomly anywhere between few and 50/60 pages. We checked 2 clutches and sensors involved in service test mode and visually, all parts in question as duplex and exit/reverse section inspected and cleaned. Firmware is latest and greatest I suspect anything wrong/warped in exit/reverse section as it can be purchased as whole unit due request from field. Jam is always the same J92-01.
    Anyone seeing this before. TIA
  • Digital
    • Feb 2021
    • 19
    From what i remember i never had any problem (so far) with reverse section or anything about J92-11. Maybe it gives this code but in reality the problem is somewhere else. If i think about jams on C3350i/4050i i always solve by changing the 2 clutches "A7AHM20501" on the paper feed section and/or by doing the modification, suggested by konica years ago, about some cushion (i attach the file with instructions).
    • Tiagocang
      • Feb 2022
      • 62
      could be the AAJNR71300 Paper Exit ASSY got some machines with that problem only jam if using duplex
      • tsbservice
        Field tech
        • 8051
        Thanks for replying. Those mods are for different paper jams, this one is only on duplex at different location. I know it's not common jam because we had 11-01, 11-02 before and did cushion and parts mod on Sparrows.
        • Woxner
          • Jul 2011
          • 852
          Take out the turn section an bend the gate tension spring. It's a slow gate causing this
          • mr_opp
            • Jul 2022
            • 4
            Open the bypass tray.
            After that open the duplex tray.
            You can see the little piece of plastic in the middle of the vertical paper transport in the duplex.
            It is very thin and hard to see plastic mustache, left uncut after mold release.
            Cut it with a knife and close the duplex.
            Go to buy beer
            • elmaligno
              Expert technician KM
              • Oct 2009
              • 302
              Go to buy beer
              Any photo?
              Field technician since 1994
              • and
                • Oct 2011
                • 99
                If the jam is similar to the photo try changing the CL5.
                This gallery has 2 photos.
                • mr_opp
                  • Jul 2022
                  • 4
                  Originally posted by elmaligno
                  Any photo?
                  Unfortunately I didn't take any pictures. Here is one photo from the web. Open that door and check the paper path for any mustache in the middle.
                  • doinbox
                    • Jan 2013
                    • 120
                    Is what I'm pointing at what you're talking about? If so what what am I cutting it up? Hard to see any other kind of guide in this area that you could be referring to.
                    This gallery has 1 photos.
                    • mr_opp
                      • Jul 2022
                      • 4
                      No, it is not that I cut. I marked the exact point in your photo.
                      • doinbox
                        • Jan 2013
                        • 120
                        Thankyou very kindly. Will give this a shot today.
                        • doinbox
                          • Jan 2013
                          • 120
                          Just wanted to update you all. Trimmed down the nipples in the duplex section and I still was getting duplex jams. Replaced Duplex clutch and now all working fine. However although I was getting Duplex Jams I was getting 32-05 Jam not the 92-01 as stated in this post. I replaced the door from another machine originally and I still got the 32-05 so it appears those duplex clutches are prone to fail considering both machines I worked on are under 10k total prints and both had failed duplex clutches.
                          • tsbservice
                            Field tech
                            • 8051
                            Clutch was first thing we replaced but at the end it was burr left from molding this plastic.
