No toner empty warning
  • Mohamed Mesbah
    • Sep 2024
    • 32
    Hi, i have a c224 that does not detect that the toner is empty, it keeps using it until the tcr value decreases. Luckily i was able to catch that.
    The toner empty warning does not show on all colors. Can someone put me in the right direction to solve the problem please?
    thanks
  • Albonline
    • Sep 2008
    • 1153
    empty and clean the toner hoppers . do not use a vacuum. the sensors are piezo and will blow with excessive static.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4755
      I've used vacuums to clean out many "4" series toner hoppers and have never blown the sensors. 3M vac's are grounded to prevent excessive static. Can't remember last time I've seen the famous blue static spark when vacuuming.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4755
        thanks
        Do you have the "consumable life reminder" turned off under system 2 in service mode? I've had machines give no warning of toner low with this setting on.
        • Mohamed Mesbah
          • Sep 2024
          • 32
          I am not really sure, i ll be checking that first before vacuming toner hopper
          • tsbservice
            Field tech
            • 8048
            Clean or replace white bushings in front of toner sub hopper.
            • Oystercopy
              • Oct 2009
              • 623
              Agree with Copyman. Been many years since I blew something with a 3M vac.. they've all got static dissipative hoses and ground connections now. In fact, the last time I blew a sensor was on a Mita analog, I think. If I remember right, it was a DC-152Z??
              OC
              • tsbservice
                Field tech
                • 8048
                I think Albonline meant developer units.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4755
                  OC
                  Wow the DC-152Z with moving platent brings back memories. Not a bad box for it's time.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4755
                    Regardless of which sensors, I've vac'd many dev unit, hoppers, etc and agree with Oyster that I haven't had a sensor blow because of static for many years.
                    • Albonline
                      • Sep 2008
                      • 1153
                      When giving advice i always look to the worst case scenario. i won't assume anybody has the proper equipment or knowledge of possible damage that they could do.
                      • Mohamed Mesbah
                        • Sep 2024
                        • 32
                        Can you please elaborate? How can they affect the "no empty toner warning"?
                        • Mohamed Mesbah
                          • Sep 2024
                          • 32
                          Cons life reminder is on
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4755
                            There has been a lot posted about the white "toner seals" and not adding toner. Use search feature.
                            Also see the attached bulletin addressing this issue
