Problem after firmware upgrade bizhub c253
  • Rafal D
    • Jan 2025
    • 10
    Hi
    After firmware upgrade i get at the MFP CONTROLLER item there is additional information concerning COPY PROTECT among others.
    Device reports error C-C163, after deleting returns at each start-up.
    Scanner function is inactive.
    Has anyone similar problems?
    IMG_2628.jpgv
  • copier tech
    • 8167
    I would rewrite fresh firmware to the compact flash card & try the update again.
    • Rafal D
      • Jan 2025
      • 10
      this is the second firmware - different version and the symptom is the same. I suspect that something else is damaged. The motherboard was replaced
      • Woxner
        • Jul 2011
        • 849
        this code refers to it being the wrong machine. set machine code. "(type) esp since you changed pwb with another machine. ck serial number if you can get into service. CC163
        (1) Contents
        Trouble type CC163: Faulty destination
        Rank C
        Trouble detection condition • The wrong model of firmware is detected in the engine during the initial connection to the engine is being
        checked.
        • Hardware signal is not fixed when the Boot started.
        Trouble isolation -
        Relevant electrical parts MFP board (MFPB)
        (2)
        • Rafal D
          • Jan 2025
          • 10
          thank you for the comprehensive answer.
          now I know what to do next
