Error PC-410: "Set the correct paper size for Tray 3"
  • CP-1015
    • Nov 2020
    • 318
    C-368 with PC-410: "Set the korrekt paper size for tray 3" What does it mean? It's always A4.
    Thanks advanced.
    • 23007
    Re: Error PC-410: "Set the correct paper size for Tray 3"
    Are there any paper jams associated? Jam codes?
    Do you hear the machine-gun sound from a jumping timing belt(s)?
    • femaster
      • May 2011
      • 1501
      There is a delay in feeding from the tray, so it appears to the copier that the paper is longer than it actually is. Could possibly be a dirty sensor, overly stiff separation torque limiter, maybe access door latch is broken causing conveyance rollers not to grab good enough, etc. The main thing is, the paper is not clearing the tray feed sensor quick enough.
      • tsbservice
        Field tech
        • 8008
        Waiting for copyrooks to post...
        • CP-1015
          • Nov 2020
          • 318
          There are no jam codes because the issue occurs after installation.
          I didn't here jumping belt. Main tray lifts 1 or 2 zentimeter. Regardless of wether there is paper in main or in sub tray.
          • CP-1015
            • Nov 2020
            • 318
            Paper does not feed at all.
              • 23007
              Check the lift plate height sensor (the sensor that detects the lifting of the pickup roller) to make sure that the sensor is moving/detecting correctly. =^..^=
              • CP-1015
                • Nov 2020
                • 318
                This is ok. I checked I/O. But belt is relaxed. Tomorrow I check if I can make it tighter. Thanks. I will report.
                • Albonline
                  • Sep 2008
                  • 1150
                  if this happened at setup, id say look at you wires/ connectors. bent pins?
                  • femaster
                    • May 2011
                    • 1501
                    That's surprising. Usually at least 1 piece of paper has fed from the tray before the "set the correct paper size" message will show. I would definitely have expected there to be a jam code if paper never fed from the tray at all.
                      • 14709
                      Thanks advanced.
                      Check the yellow guide in between paper stacks to be sure it moves freely. Check that tray is lifting evenly.
                      • tsbservice
                        Field tech
                        • 8008
                        See this post from copyrooks:
                        PC-410 set the correct paper size for tray 3
                        Also I would double check Connectors as mentioned already.
                        • CP-1015
                          • Nov 2020
                          • 318
                          Solved. It was a scrap of paper in the connector behind sub tray. My customer had removed the paper so neatly that it was only visible from the rear after dismantling the tray. (Error code in the meantime: C-0210) Thanks all for help. Have a beautiful Sunday!
                            • 23007
                            Congratulations on your success! =^..^=
                            • Norbi-HU
                              • Sep 2023
                              • 2
                              I have stucked elevator motor (M134) and shifter motor (M133).
                              I clean both of them and problem solved!
