c284e vs. O365 Scan-to-Mail
  • Hornochse
    • Feb 2023
    • 27
    #16
    Try to leave only TLS 1.2 available under SSL/TLS Version Setting
    Thank you, I tried this but didn't work either :-(
    Here are my settings.
    • Gift
      • Mar 2011
      • 2459
      #17
      We also received calls from two more xx4e customers facing the same issue.
      • Hornochse
        • Feb 2023
        • 27
        #18
        if there is any solution, I'd be very interested in ;-)
        • Gift
          • Mar 2011
          • 2459
          #19
          No, it's very likely that KM can't and won't provide any solution due to the age of this series (almost a decade passed since the last units has been produced). Soi it's either "sit and wait/hope" or get something newer. Meanwhile you can use scan to folder/USB stick instead.
          • occus
            • 337
            #20
            Same here with a c258. Works until last friday...
            • Gift
              • Mar 2011
              • 2459
              #21
              ok - please inform us if the latest firmware will help for the 8-series
              • occus
                • 337
                #22
                Found this text:
                Microsoft began disabling AUTH PLAIN and AUTH LOGIN authentication methods in 2021, and these will be disabled by default starting in 2025.
                In my case a other tech has to find the solution, i let you know the solution after i got feedback from him.
                • progoffice
                  • Nov 2008
                  • 334
                  #23
                  I ran into this as well on a C284e yesterday. For me it was very intermittent, but would mostly fail with the same error code 107. The customer has a C458 using the same email credentials and it's still working fine. Are the 8 series machines going to have this same issue soon? I have yet to set up a machine using the OAuth 2.0 method, but I predict we will all become familiar with this process soon on machines that support it.
                  • Duplicator
                    • May 2022
                    • 245
                    #24
                    Yup come September we will all have to start using it.
                    "Although SMTP AUTH is available now, we announced Exchange Online will permanently remove support for Basic authentication with Client Submission (SMTP AUTH) in September 2025."
                    I'm so excited for the phone calls....Not....
                    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
                    If I helped you out, please give me a thumbs up! It helps my reputation.
                    • menon
                      • Sep 2017
                      • 2
                      #25
                      Hi Guys
                      here the same problem. Olivetti MF282Plus formerly (bizhub C284e) not sending to O365 from a couple of days. We have a dozen of series 4 that send any more mails to O365. It seams a problem of Series4. Using same account on series 8 or newer works. Till now no solution found.
                      It only a problem if Basic authentication i used.
                      Hoping it cames some solution from KM.
                      • Duplicator
                        • May 2022
                        • 245
                        #26
                        Originally posted by menon
                        Hi Guys
                        While I don't have any knowledge of what happens at KM.... The only firmware I've seen released to support the new OAuth protocol is for the i-series machines.
                        If that holds true....that's going to be a major issue...
                        • LP59RI
                          • Feb 2025
                          • 1
                          #27
                          We had the same problem this week, customers calling that email stopped working with office365
                          Just this morning we found that it is working again on our local machine.
                          We contacted some customers who reported the problem and they confirm it is working again!.
                          Please check with your customers and report the results here.
                          • Hornochse
                            • Feb 2023
                            • 27
                            #28
                            unfortunately not working for me
                            • Gift
                              • Mar 2011
                              • 2459
                              #29
                              Got a hint that MS did something chipre related and is considering to reverse it so existing configs will work (at least until sept 2025). You can also try and use one of these IPs for MS SMTP server that might work:
                              52.97.211.210 / 52.97.146.194 / 52.97.173.18 / 52.97.129.242 / 52.97.146.162 / 52.97.211.226
                              • Copier Tech Specialist
                                • Jan 2025
                                • 19
                                #30
                                Enable App Password in Office365 or in Gmail to enable scan to email feature in Konica Minolta Printers. This works and it is tested in Konica Minolta 4 series and 8 series.
                                Delete the existing self signed certificate and create the new one with RSA-2048_SHA-256
                                Microsoft Office365
                                Gmail
                                Like comment and Subscribe
