Can C71hc be converted to C1070
C71hc to C1070
The consumables, especially developers for high chroma, DV-615 are no longer readily available, so i want to start using DV-614. Im wondering what other areas to look at? I use the inbuilt IC-602 controllerDgtalComment
This is supplies for C1070
And this is for the C71hc
Black and yellow developer ae the same . The problem you may have is the C1070 toner bottles fitting in the C71hc. I dont think you would have trouble putting in C1070 developer in the c71hc, but I wouldn't try both of the different developers at the same time.Comment
For toner bottles, we can always manually transfer the powder.
My issue is what are the board or firmware differences, if any?DgtalComment
To your question, the answer is yes. If your problem is only with the consumables, you may have a problem with the developers and perhaps the cylinders. Replace the developers with C1070 ones and change the output profiles inside the IC-602 controller. You will have C1070 quality in a C71hc. If the cylinder is different, it will only be the metal pin on the right side, like in the C1070L. Just remove the pin and be happy.
To your question, the answer is yes. If your problem is only with the consumables, you may have a problem with the developers and perhaps the cylinders. Replace the developers with C1070 ones and change the output profiles inside the IC-602 controller. You will have C1070 quality in a C71hc. If the cylinder is different, it will only be the metal pin on the right side, like in the C1070L. Just remove the pin and be happy.Dgtal👍 1Comment
