C71hc to C1070
  • adeyemi
    • 378
    C71hc to C1070
    Can C71hc be converted to C1070
    Dgtal
  • Ziggy
    • Feb 2018
    • 789
    What are you exactly trying to accomplish ? Not sure what you mean by your question
    • adeyemi
      • 378
      The consumables, especially developers for high chroma, DV-615 are no longer readily available, so i want to start using DV-614. Im wondering what other areas to look at? I use the inbuilt IC-602 controller
      Dgtal
      • Ziggy
        • Feb 2018
        • 789
        This is supplies for C1070
        And this is for the C71hc
        Black and yellow developer ae the same . The problem you may have is the C1070 toner bottles fitting in the C71hc. I dont think you would have trouble putting in C1070 developer in the c71hc, but I wouldn't try both of the different developers at the same time.
        • adeyemi
          • 378
          Thank you so very much!
          For toner bottles, we can always manually transfer the powder.
          My issue is what are the board or firmware differences, if any?
          Dgtal
          • Ziggy
            • Feb 2018
            • 789
            I'm sure there are board differences as far as firmware I'm not where I can look at the moment but it's probably different also.
            • Ziggy
              • Feb 2018
              • 789
              Sorry about slow response Firmware is the same I'm looking up boards now
              • Ziggy
                • Feb 2018
                • 789
                Better yet PM me your email address and I can send you the parts manuals
                • adeyemi
                  • 378
                  Thank you. I will do that right away.🙏
                  Dgtal
                  • tulintron
                    • Jul 2014
                    • 668
                    To your question, the answer is yes. If your problem is only with the consumables, you may have a problem with the developers and perhaps the cylinders. Replace the developers with C1070 ones and change the output profiles inside the IC-602 controller. You will have C1070 quality in a C71hc. If the cylinder is different, it will only be the metal pin on the right side, like in the C1070L. Just remove the pin and be happy.
                    https://www.copytechnet.com/images/smilies/cool.pngNada como dia após diahttps://www.copytechnet.com/images/smilies/cool.png
                    • tulintron
                      • Jul 2014
                      • 668
                      Remembering the toner. Empty the toner hopper and remove the bottle caps at the toner supply inlet. (Toner Bottle).
                      • Ziggy
                        • Feb 2018
                        • 789
                        Sent manuals this morning
                        • adeyemi
                          • 378
                          Thank you all. I got it done successfully. Just to be sure, how do i change the output profiles inside the IC-602, would that be via color centro?
                          Dgtal
                          • tulintron
                            • Jul 2014
                            • 668
                            exact!
                            • bcp
                              • Mar 2008
                              • 57
                              Try aliexpres. https://www.aliexpress.com/w/wholesa....home.search.0
