Konica c364e freeze when hard disk is connected
  • asadk70
    • Sep 2023
    • 5
    C364e Konica freeze when h.d is connected when I disconnect hard disk is working fine print copy but can’t do scan because of hard disk I tried ssd board do physical format and logical format tested with 4 hard disk no luck
    last option to swap mfp board
    can anyone send me mfp reset tool
    many many thanks
    asadk70@gmail.com
  • copier tech
    • 8144
    When you fit another HDD does the C364e prompt you to format it ?
    Also check the HDD is set to installed in CE mode.
    We can supply the reset tool if you want to try it.
    www.printerfirmware.co.uk
    • asadk70
      • Sep 2023
      • 5
      Yes when I fit another hdd it’s asking for format but after formatting when machine boot up after few seconds it’s hang
      in service mode hdd is installed
      • Duplicator
        • May 2022
        • 245
        Have you tried running the diagnostic mode?
        Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
        If I helped you out, please give me a thumbs up! It helps my reputation.
