Bizhub C224E
  • Frankrw
    • Nov 2012
    • 12
    [Misc] Bizhub C224E
    Hi
    Have a problem with Bizhub C224E. When printing single sided prints are very good but when doing double sided, the second side is very poor. Looks like not transferring image properly.
    Help will be appreciated
  • Cantechman
    • Nov 2008
    • 227
    Re: Bizhub C224E
    Originally posted by Frankrw
    Hi
    I would try a new 2nd image transfer roller.
    • GIUBOSS
      • 1392
      Re: Bizhub C224E
      Have you tried with single colors or with black? Often even the charge rollers give these problems ...
      • Synthohol
        Certified Konica Expert
        • 5806
        Re: Bizhub C224E
        Is the paper damp or humid?
        The copier copies second side first and first side second so if the first side is dense enough it has run through the fuser already and dried out and accepts more toner on the page.
        Copy 10 pages of test then put them back in and copy on the back of the same 10 pages see if round 2 is darker.
        • Frankrw
          • Nov 2012
          • 12
          Re: Bizhub C224E
          Thanks for the reply
          I would agree with damp paper., but if I do single copies whether its 1 or 50 they are all good so it cant be damp paper. Its only does it on the duplex
          • Albonline
            • Sep 2008
            • 1144
            Re: Bizhub C224E
            Try setting to a heavy paper type to see if there are any changes, The machine shifts hv output on 2nd side, maybe the shift is effecting 2nd side 2nd transfer adversely.
            • Frankrw
              • Nov 2012
              • 12
              Re: Bizhub C224E
              Thanks. Will give it a try
