I asked before, but lost the answer....
  • Hansoon
    • Sep 2007
    • 3381
    Guys, I asked here before which 2-GB USB-Sticks are recommended by KonicaMInolta for updating the firmware and movie file for the BH-C-284e series, but I lost it and cannot find it with the search function here in the panel. There was a list from KonicaMinolta with advised sticks. Can I have that list once again, please? Thanks!
    Hans
  • Duplicator
    • May 2022
    • 245
    I can't say I've ever seen a list of approved sticks but you can use larger sizes without issue. It just has to be formatted correctly. The trick is FAT32 with LBA off or make a 4GB partition instead of the entire thing. From my understanding there is an HP format tool that does this on Windows. (https://filehippo.com/download_hp-us...e-format-tool/) The format tool built into Windows will not do what you want and will create a disk that is unusable for a Konica if it's larger than 4Gb.
    Currently we use 64Gb ones because they were easy to get from Amazon.
    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
    If I helped you out, please give me a thumbs up! It helps my reputation.
    • Synthohol
      Certified Konica Expert
      • 5820
      its old but valid
      • copyman
        Owner / Technician
        • Sep 2005
        • 4679
        Hi, This is what I've been using since Kon/Min started using USB to update firmware (see pic)
        • Copier Tech Specialist
          • Jan 2025
          • 19
          This ScanDisk USB is the best choice for uploading firmware on all Konica Minolta printers, supporting all models.
            • 37474
            What I have used in the past is minitool partition wizard
            • Duplicator
              • May 2022
              • 245
              That should work too.
              I've been using Gparted. It's free and works. Just start up the live CD on an old PC, and format a few USB sticks. Then we hand 'em out to our field techs.
