C4080 color registration
  • kenpio
    • Dec 2015
    • 201
    [CQ] C4080 color registration
    Good Morning,
    I have a customer with a C4080 and when they run thick 12x18 paper, it is business card thick. They are running these card, like 24 up, the lead edge is right on and then toward the middle of the page you can see the magenta creeping out of the print. then toward the trail edge the cyan may creep out. We have tried fuser speed, changed the transfer belt timing wheel, and the lower metal roller, updated one. Customer ends up doing the job on the Xerox. We are trying to sell them on another KM but with this problem they are kind of hesitant. Also noticed another customer doing the same thing, but they are not that critical. Thanks in advance.
  • wjurls
    • Feb 2017
    • 495
    Not sure if the setting exists on the C4080, but on the C1070 this would happen if the second transfer pressure was too high. Switching it from Auto to Low pressure under paper settings would cure it.
    • kenpio
      • Dec 2015
      • 201
      I do believe we tried that too. There are a couple different setting for the transfer roller pressure. Like low, medium, high and auto. Tried them all.
