Removal of Finisher on Bizhub C552
  • Orlando Perrone
    • Feb 2025
    • 2
    Hello. I have come upon a Bizhub C552 from a school with what would be a lifetime of toner. I just needed it to be a large printer/copier. I don't need holes punched, I don't need staples, I just want it to be a big ol' laser printer. I find myself clearing jams out of the finisher quite often. Is there a procedure to remove it and just use the main unit? There is a large space of what seems to be an output tray just under the scanning unit. If I could remove the finisher and use that tray as output, that would be ok with me.
    Please advise.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4756
    Just unplug finisher from machine and remove it. No settings or changes have to be made. The finishers are "plug & play".
    You have to remove the transport bed along with finisher. Pages will fall onto metal plate inside cavity. There is a tray that goes inside the cavity OT-503. I have a customer that did the same thing with removing the finisher and they have been using it while I've been trying to find OT-503. Been almost a year and cannot find it. Reason they are hard to find is most of these 50+ ppm models were sold with finishers. Best of luck
    • Orlando Perrone
      • Feb 2025
      • 2
      Ok. I unplugged everything that was attached to it, and it complained about something being opened and the screen didn't point to whatever it was.
      • kingarthur
        • 1385
        Have you removed the bridging unit, the large part that sits under the scanner. I can't remember, if when the finisher was installed a "bridging" connector had to be removed just behind the control panel, in which case, if that's not refitted, you may have problems. It's been awhile since I saw one of these.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4756
          Did you remove and unplug connectors with machine off? Did you try turning off and on with "main power switch"? Also open and close front door to reset? As a last resort you can initalize the machine in service mode.
          FS-527 install instructions & OT-503 attached
