Hello group, I'm trying to update the fw of the c12000 and now it gives me the c-dc20 error and I've tried everything and I can't solve it. It has already updated it to the latest version of fw and there is still an error. There is nothing in the manual about this error.
Error c-DC20 c12000
is the hdd kit attached?
Re: Bizhub C3070 with C-DC20
Your model not listed but its worth a shot to put latest firmware on machine
C-DC20.
Known Error
Related Products:bizhub PRESS C6000,bizhub PRESS C7000,bizhub PRESS C7000P,bizhub PRESS C70hc,bizhub PRO C5500,bizhub PRO C5501,bizhub PRO C6000L,bizhub PRO C6500,bizhub PRO C6500P,bizhub PRO C6501,bizhub PRO C6501P
Related Options:
Error
C-DC20
Root Cause
C-DC20 (CDC20) code at power up.
Workaround/Fix
CAUSE: Corrupt firmware.
SOLUTION: Update firmware to the latest level. The latest version firmware or system software is available via the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'.
SPECIAL NOTE: Solution contribution by Ed Bellone, Production Print/SSDWe know a thing or two because we've seen a thing or two.
The medication helps though...👍 1Comment
In manuals for other devices, C-DCXX is related to security. In addition to the update, check if the Serial Number field is ok. Something happened that invaded the system security and displayed the C-DC20 error.
Any board replacement?Comment
Why did you update the firmware? Was there a reason? What version was it before the update?
Thanks to everyone, I was able to solve the problem, I updated the firmware to V.70
thanks
