Error c-DC20 c12000
  • romario
    • Jun 2020
    • 193
    Error c-DC20 c12000
    Hello group, I'm trying to update the fw of the c12000 and now it gives me the c-dc20 error and I've tried everything and I can't solve it. It has already updated it to the latest version of fw and there is still an error. There is nothing in the manual about this error.
    thanks
  • wjurls
    • Feb 2017
    • 501
    Can you confirm that error code? I can't find it in the SM.
    • romario
      • Jun 2020
      • 193
      C-DC20 It doesn't appear in the manual
      thanks
      • wjurls
        • Feb 2017
        • 501
        Well aint that lovely? I can't find anything in bulletins or knowledge base either.
        • romario
          • Jun 2020
          • 193
          very strange this problem
          thanks
          • Synthohol
            Certified Konica Expert
            • Mar 2016
            • 5892
            is the hdd kit attached?
            Originally posted by Markks
            Re: Bizhub C3070 with C-DC20
            Your model not listed but its worth a shot to put latest firmware on machine
            C-DC20.
            Known Error
            Related Products:bizhub PRESS C6000,bizhub PRESS C7000,bizhub PRESS C7000P,bizhub PRESS C70hc,bizhub PRO C5500,bizhub PRO C5501,bizhub PRO C6000L,bizhub PRO C6500,bizhub PRO C6500P,bizhub PRO C6501,bizhub PRO C6501P
            Related Options:
            Error
            C-DC20
            Root Cause
            C-DC20 (CDC20) code at power up.
            Workaround/Fix
            CAUSE: Corrupt firmware.
            SOLUTION: Update firmware to the latest level. The latest version firmware or system software is available via the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'.
            SPECIAL NOTE: Solution contribution by Ed Bellone, Production Print/SSD
            • romario
              • Jun 2020
              • 193
              Today I put the latest Ver.70 on it and it still has the same error
              thanks
              • tulintron
                • Jul 2014
                • 668
                Why did you update the firmware? Was there a reason? What version was it before the update?
                In manuals for other devices, C-DCXX is related to security. In addition to the update, check if the Serial Number field is ok. Something happened that invaded the system security and displayed the C-DC20 error.
                Any board replacement?
                https://www.copytechnet.com/images/smilies/cool.pngNada como dia após diahttps://www.copytechnet.com/images/smilies/cool.png
                • romario
                  • Jun 2020
                  • 193
                  Thanks to everyone, I was able to solve the problem, I updated the firmware to V.70
                  thanks
