Bizhub 282 C2557 error
  • deputydogg
    • Nov 2015
    • 172
    We took this machine in from customer who bought new one. It worked for about 4 copies and now displays C2557. I saw a youtube on how to reset it but didn't work.
    What is this code indicating ?
    Thanks,
    Dave
  • Woxner
    • Jul 2011
    • 851
    Re: Bizhub 282 C2557 error
    Toner ratio code. Could be toner add assy stays locked on. Or old dev.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4724
      Clear drum & developer counters, remove Image unit and install NEW drum & developer. Run F8 in service mode after replacing Drum & Dev and will be good to go.
      • femaster
        • May 2011
        • 1514
        Be aware that neither the drum nor the developer is available direct from Konica any longer. Tried to get both about a month ago for an old machine that a customer refused to give up, and the order form stated that the items are no longer available for order.
