konica minolta c300i multi scan off platten question
  • brent
    • Nov 2008
    • 1214
    so I am stumped on a machine. when I want to do a copy off the original glass it wants to make me do a 2 sided.. or seperate scan. I do think I have small originals on and on the section about seperate scan it was turned off.. I turned it on in admin settings it didnt change anything.. if I make a copy through the doc feeder no problem only on the glass is not working. is there a setting for multiple originals off glass or seperate scan or something? help my brain is fried trying to find the setting.. thanks in advance
    brent
  • tsbservice
    Field tech
    • 8054
    Re: konica minolta c300i multi scan off platten question
    • [Utility]
      • [Utility]
        • [Copier Settings]
          • [Basic Setting]
          • [Default Copy Settings]
      • 23010
      • [Utility]
        • [Utility]
          • [Copier Settings]
            • [Basic Setting]
      Do you have duplex originals set as a scan default? =^..^=
      • brent
        • Nov 2008
        • 1214
        its so simple that I can not find the setting.. duplex originals as a scan setting. I do not think so nowhere does it say duplex. unless its a setting in the menus
        also if I could set it to multi scan off glass and the set up default settings I would be fine.. but everything I see indicates its simplex copies. like I said its a simple setting I cant find ugh.. why anyone would have set this setting to do this is beyond me.. I h ope I have given enough information for some more help
        thanks guys sorry
        brent
          • 14985
          thanks guys sorry
          brent
          There is a "serperate scan from platen" setting under Utility, user settings, system settings. I think it is on the second page.
            • 23010
            On Konica Minoltas, you set up the features you want as default. Then go to the specified menu and select "Current Settings" to lock it in. The other choice is "Factory Default" which also might solve your issue. =^..^=
            • brent
              • Nov 2008
              • 1214
              it wont work. it is set up for simplex. its set up for simplex scanning.. I went into system settings and turned off the seperate scan from platten.. still wont work
              I guess its not my day yet lol
              brent
              • tsbservice
                Field tech
                • 8054
                Burn that damn thing...just kidding 😊
                Maybe it's time for Clear All Data.
                • brent
                  • Nov 2008
                  • 1214
                  the roof is on fire.. love that song!!
                  • brent
                    • Nov 2008
                    • 1214
                    thanks everyone.. we had to do a data all clear.. it absolutely was stuck. and now it works.. appreciate everyones advice
                    brent
                    • Woxner
                      • Jul 2011
                      • 853
                      All you had to do is turn sort mode off. It was set to auto sort. This causes platten copies to ask you to continue.
