konica minolta c3320i noise
  • brent
    • Nov 2008
    • 1208
    ok a new machine I set up 3 months ago now it has a pretty noticable noise from the exit section of the machine.. I used some lubrication on the bottom 2 white rollers and I thought it went away.. but it didnt. it seems the bushings to any of the exit rollers are really hidden in the front and the back of the machine.. any ideas? it is just annoying for the customer. thanks in advance
    brent
  • rrrohan
    • Sep 2011
    • 1977
    Re: konica minolta c3320i noise
    I have same issue on 4050i. This one is also less than 3 months old. I haven't returned yet I'll report back. What did you use as lubricant?
    Sent from my Pixel 4 XL using Tapatalk
      • 22946
      If you pull out that exit section you'll discover that there aren't really any separate bushings, just holes in a plastic frame with no factory lubrication. It's not so easy to remove ... but once you do, I used Mobilgrease28 (red grease) to lubricate each shaft and idler. It quieted right down.
      I was a bit disappointed how cheaply made it is. =^..^=
        Great info. but you usually have pictures.
          • 22946
          8-27-2021, but sorry, no pix this time. I seem to recall that it's all black parts on an all black frame. The picture didn't come out very well. =^..^=
          • brent
            • Nov 2008
            • 1208
            believe it or not.. I have a video on my phone of the annoying noise..
            my customer just cant stand it.. I said well at least think of the positive.. its printing right? lol thanks I will check into this
            brent
            • tech51
              • 846
              • brent
                • Nov 2008
                • 1208
                it should just work more better lol thanks for the info
                brent
                • Cantechman
                  • Nov 2008
                  • 226
                  brent
                  This should help.
                  • brent
                    • Nov 2008
                    • 1208
                    thank you so much. I have printed out the tutorial and will go and visit the machine when the time comes..
                    I love this site and people who donate and help forward the cause
                    brent
