Bizhub pro 951 error code C-3905
  • M3HR4N
    • Jun 2015
    • 34
  • tulintron
    • Jul 2014
    • 668
    Re: Bizhub pro 951 error code C-3905
    Hardware issues. Professionals can solve, Hytek Repair
    • copy_kid
      • Jan 2011
      • 13
      We are having the same issue on a Pro 951... In the service manual it points to TH2, not TH1 as you have written... But so far we have replaced the TH2, machine heats up and right when "ready to print" is displayed, it shows C-3905 again! I have taken the fusing unit and mounted it on another machine and it works perfect. When put on the original machine it gives the code again...
      Cecked ICP 4 on PRCB, it is good
      Checked all ICP's on PRCB and they work good
      Checked the connector btw fusing unit and machine... it is good.
      Found an article on infohub regarding this issue (find it attached), changed the sleeved (even though the solution would have been absurd to work).
      Uploaded new firmware v52 on the whole machine! Still no luck!
      It is getting frustrating!
      The problem is clearly related to the TH2 thermistor, but the fusing unit works perfect on another machine.
      Next, I will mount a different fusing unit on the original machine and let you guys know if I have any luck. If not, next thing I will do is mount a different PRCB...
      I still think the problem is the PRCB... Like it says in the troubleshooting guide attached ("damaging the resistor on the PRCB") one resistor might be broken... The ICP's are all good!
        • 23010
        Have you tried clearing the fuser error by resetting DIPSW 3-1 from 1 > 0?
        • M3HR4N
          • Jun 2015
          • 34
          Guys the problem solved I already mention it there is no way you should change the PRCB.
          • copy_kid
            • Jan 2011
            • 13
            Problem solved? How? What was the solution then?
            • copy_kid
              • Jan 2011
              • 13
              C'mon dude! Realy?
                • 23010
                Originally posted by copy_kid
                C'mon dude! Realy?
                I really hope you can communicate a little better than this. =^..^=
                • Toxic
                  • 698
                  Come on guys, calm down, ne need for stressing because of little misunderstanding.
                  Let me clarify this if i also understood good
                  Solution was replacing PRCB.
                  copy_kid get little bit angry because blackcat ask him is he done basic procedure for resetting error and he got offended by that because he have some knowledge beyond that level.
                  Correct me if i am wrong.
                  • tsbservice
                    Field tech
                    • 8064
                    Not at all At least for me.
                    • wjurls
                      • Feb 2017
                      • 505
                      We've had a number of 951's throw a hard C-3905 (like 15+ of them). No idea what actually causes a machine to throw that code. Seeing how it always happens at a school site though, we suspect it may be due to fast cycling of the main power switch. Teachers aren't known for patience with the equipment. Hytec always has boards on hand and/or can repair yours.
