bizhub c224e toner clot
  • konica7022
    • Nov 2008
    • 132
    hope you all doing well especially the old chaps that have been constantly helping others (salute to you all)
    bizhub c224e .. toner started forming clots (i was using compatible toner)
    cleaned added new k developer ... switched to genuine toner .. but still the issue remains
    already changed all drums units to genuine ones
    have issue in blue as well when i print moreWhatsApp Image 2021-12-09 at 11.19.20 AM.jpgWhatsApp Image 2021-12-06 at 10.51.16 PM (1).jpgWhatsApp Image 2021-12-06 at 10.51.16 PM.jpg
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    Re: bizhub c224e toner clot
    have issue in blue as well when i print more[ATTACH=CONFIG]51132[/ATTACH][ATTACH=CONFIG]51133[/ATTACH][ATTACH=CONFIG]51134[/ATTACH]
    When you say you "cleaned added new developer" what developer? Not aware of any developer for this machine?? Developer is mixed in with toner and constantly being refreshed.
    Still looks like developer unit issue from bad aftermarket toner.
    Since you put new "Genuine" K toner in run 40-60 K half tone test pages you should see fill come back in as long as it has good drum. Do the same for Cyan, if you can find genuine TN321 toner. I've saved many expensive dev units this way.
    This procedure can also be used to turn a K dev unit into a color. Around 40 11x17 halftones you will see the K turning to whatever color, by page 60 it will have changed to that color. K dev units are much less then color $150 vs $500+ !!!!
    • tsbservice
      Field tech
      • 8020
      Go in service mode and print CMYK halftone patterns at 130 values what they look like? Clean IDC sensors as well they are clogged for certain.
      • romario
        • Jun 2020
        • 192
        by chance if you cleaned the laser with the stick? it is not too much to ask. It looks more than the K laser It is dirty with toner
        thanks
        • konica7022
          • Nov 2008
          • 132
          yes bro tried that .. and even had the entire laser unit removed and cleaned and re installed
          after few day same issue
          these are the latest images of the drum and dev unit
          WhatsApp Image 2021-12-18 at 7.25.41 PM.jpgWhatsApp Image 2021-12-18 at 7.31.49 PM.jpgWhatsApp Image 2021-12-18 at 7.31.38 PM.jpgWhatsApp Image 2021-12-18 at 7.31.28 PM.jpgWhatsApp Image 2021-12-18 at 7.31.11 PM.jpg
          • konica7022
            • Nov 2008
            • 132
            was cleaned, while i cleaned the transfer belt unit and also changed TB cleaning Blade later
            • konica7022
              • Nov 2008
              • 132
              Removed the K developer unit .. flushed out old dev powerd, cleaned the unit filled with new dev powder
              and still the same issue
              • tech51
                • 846
                Genuine k dev unit and drum and a genuine replacement drum in the cyan should do it along with a thorough clean up of the ph etc.
                • femaster
                  • May 2011
                  • 1514
                  [ATTACH=CONFIG]51151[/ATTACH][ATTACH=CONFIG]51152[/ATTACH]
                  Looking at those pictures, you have an excess of developer in the front end of the unit, and none in the middle or back of it. You need to cover the toner addition tube with your thumb, and shake that thing front to back to evenly distribute the developer in the unit. If it was evenly distributed to start with and ended up like that, then there is something else wrong. Augers not working correctly, or maybe the copier is not level? Is the floor where the copier sits slanted making the front side of the copier lower than the back?
                  • Gab
                    • Aug 2015
                    • 671
                    Konica machines accept not ghenuin toner vey well.
                    obviosly there is a problem in developer unit. Developer are not evenly distributed on magnet roller perhaps there is an obstacle bothering developer to go to right side if developer unit or the film above the mag reller . You have to check if there is the correct amount of developer in unit at the side that there is not enough developer on mag roller. Something prevents dev to do to mag reoller . Open and check.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4723
                      You have been given some good advice but the best advice given was to replace the Drum(s) & Developer unit(s) with GENUINE Kon/Min.
                      If you don't want to do that and insist on using old / generic consumables then there is nothing anyone can do for you here.
                      Best of luck
