Accurio Press C4070 - Can't access Print Manager from touch panel
  • gavrielx
    • Oct 2015
    • 59
    Hi,
    For some reason I can't access PRINT MANAGER via the touch screen I get a TIMEOUT error
    Through the computer everything works fine
    I would appreciate your help
    Regards,
    This gallery has 1 photos.
  • ps-tech
    • Oct 2023
    • 7
    Main body is conected to network? You have to conect both controller and main body to network and set no ip filtering. Then restart
    • gavrielx
      • Oct 2015
      • 59
      Hi ,
      change from "Not Synchronize" to "Synchronize" on the "Synchronize Main Body & Controller power" menu fix the issue.
      • Ziggy
        • Feb 2018
        • 801
        Originally posted by gavrielx
        Hi ,
        I have never had a problem leaving the Fiery not to synchronize power with the main engine. I don't like synchronizing power because when you have to reboot the machine to clear an error if you don't wait for fiery to shut all the way down before turning machine back on , and most customers don't, then you send an on signal to the fiery while its trying to shut down. This could cause the fiery to crash. You could have had your problem because you didn't let the machine fully boot before turning on the fiery .
        On production machines the printer must be fully up before turning on the fiery.
