c650 no print but good ping...
  • Synaux
    • Mar 2012
    • 1224
    I still have a few of these turds still pumping out mostly B/W forms, etc.
    This machine will not print from the network.
    I am able to ping it.
    Prior to this DHCP auto-enabled, made the old static IP and worked for about a month.
    I am pretty sure I still have the NIC reset and the latest firmware on preloaded CF cards somewheres so I will attempt that tomorrow.
    If not I might need to phone in a favor to one of you old farts!
    Any other suggestions though?
  • Albonline
    • Sep 2008
    • 1153
    Re: c650 no print but good ping...
    supplies? beyond life? does the job spool then delete?
      • 23010
      I had three of these die of HDD failure. I'd suspect that.
      One of those customers was using the FILE_SHARE as their electronic file cabinet and lost several years of documents. =^..^=
      • Synthohol
        Certified Konica Expert
        • 5879
        have you tried your laptop directly to it?
        • Synaux
          • Mar 2012
          • 1224
          Sorry for the late response, been working an unrelated job--plenty of hours--near worthless wages...
          Holey crap I completely forgot about the HDD!
          The DHCP auto-enabling threw me off.
          In short, this makes total sense
          I will check
          That is on my list but I need to make another crossover cable and find my laptop
          FYI, the NIC reset FW didnt work....
          Not sure if Im going to make a visit today, but I will report back soon.
          Thanks!
          • Synthohol
            • 5879
            Cross over cable has not been required for a long time.
            Just use a regular patch cable.
            • peter42
              • Jan 2012
              • 110
              If ping is ok, next step is open website of the copier. If that fails, remove Cat5-line from copier and ping again.
              Its not the first time, that i got an answer from an iphone or samsung device new on the network.
              • emujo2
                • Mar 2017
                • 1579
                Does the job log indicate that the print was sent, but deleted for some reason? When you send a job, does the Blue Data light indicate there at least may be some communication. Remember, PING is nothing more that a tool to establish basic communication with a another network node. It cannot tell you if printing, scan, SNMB ect ports are open. Just the fact that this is a C650 would give me pause to really spend a lot of time trying to torubleshoot this..If you are running Win 11 it may not ever work..If you can open the web page using the IP info you have, and the workstation is allowed to run TELNET, you can open port 9100 and send a job just to test the printer. If this works try using a old HP PCL generic page printer to see if the machine is accepting prints. What fun...
                • Synaux
                  • Mar 2012
                  • 1224
                  Hey guys, I really appreciate the thoughtful responses; however, I had gone dun f'd up--but at least I figured it out a while ago...
                  This business has a 24port switch (cat5) full of connections, I had made a cheat sheet for ALL the IP addresses and it has worked great until my original posting.
                  and
                  a
                  long
                  sigh:
                  I had completely forgotten that half a dozen capacitors blew on the fiery (that I took off many moons ago).
                  So yeah... I was using the damned fiery IP on the print driver!
                  Many thanks, regardless
                    • 23010
                    LOL. =^..^=
