change strgb konica minolta c250i
  • enricocopyline
    • Jun 2018
    • 122
    #16
    the problem is that you can't even update it, it turns on for 5 seconds and then turns off
    • Max
      • Oct 2011
      • 561
      #17
      If the copier reboots after CPU 2 update, then your CPU board is done. The only way is to replace it.
      • Dianon
        • Apr 2025
        • 16
        #18
        We have the same problem with 3 C250i after updateing "power control cpu1" or "power control cpu2"
        all three where from first generation, that one where you have a solid stop button with a red dot at the back from the panel. the newer one have a button with a hole in it (you can clearly distiguish it by the ring pattern on your fingertips after holdig the button when you initialize a FW update )
        Do anyone know what power control CPU1 and CPU2 do?
        For what they are intended?
        Assuming from the name, the control the voltages for the cpu.
        I searched throug KIKU and found, that KM changed something on the voltages applied to the CPU to get rid of an C5372 error in energy save mode. And that you have to update "power control cpu2" for this to apply.
        From this, i think i am right with my asumption.
        Could it be, that KM changed the CPU like the storage board within production, and that older cpu board don't work well with lower voltages?.
        • GrahamMiles
          • Jan 2025
          • 2
          #19
          Adjusting sRGB settings on the Konica Minolta C250i can impact color accuracy significantly.
          • WisamM
            • Feb 2023
            • 23
            #20
            I tried the procedure but when I updated the cpu2 and rebooted the machine started to reboot continuously without being able to do anything else
            Unzip the attached file, copy the Reset tool to an empty USB memory (formatted FAT 32) and start the machine while pressing the STOP button (back the control panel).
            It will show "Data initialization complete" then install the latest F.W.
            Good luck.
            Waiting for feedback.
            • Dianon
              • Apr 2025
              • 16
              #21
              Good luck.
              sadly didn't work on my devices
              machine reboots constatly after 5 secounds
              • Max
                • Oct 2011
                • 561
                #22
                Reset tool won't help you in this case.
                • konicatoshiba
                  • Jan 2023
                  • 33
                  #23
                  Originally posted by stronghold
                  CPU1, CPU2, Boot Rom Firmware Update Procedure
                  #### Preparation:
                  1. Remove the STRGB (storage module) from the device.
                  2. Connect it to a PC directly or via an NVMe adapter.
                  3. Delete all existing partitions from the device where the STRGB was taken.
                  4. Disconnect the STRGB from the PC and install it into the target MFP.
                  5. Download the latest firmware (current version: FW AA7N0Y0-F231-GC2-RF).
                  6. Copy the FW0020 folder (containing the firmware) to the root of a FAT32-formatted USB drive.
                  7. Insert the USB drive into the USB-A port on the side of the device.
                  #### Entering Firmware Update Mode:
                  8. Power on the MFP in firmware update mode:
                  - Before turning on the 220V power, press and hold the STOP button (located on the back of the display under a small cover).
                  #### Flashing Process (CPU1, CPU2, Boot ROM):
                  After the device boots from the USB drive:
                  9. Select [Machine Type Select] in the Firmware Update menu.
                  10.
                  - For C450i/C451i/C550i/C551i/C650i/C651i:
                  Press [(1) (7) (2) (9) (3) (8)] (in the red frame), then tap [OK].
                  - For C287i/C257i/C227i/306i/266i/246i/226i:
                  (Since the on-screen keypad is missing, press the hardware buttons in this order
                  [Start] → [Reset] → [Stop] → [Stop] → [Reset] → [Start], then tap [OK].
                  11. Select [Other FW Update].
                  12. Choose CPU1 → START and wait for the update.
                  13. Reboot the device after completion.
                  14. Repeat steps 8, 9, and 10 to re-enter firmware mode.
                  15. Select [Other FW Update].
                  16. Choose CPU2 → START and wait for the update.
                  17. Reboot the device after completion.
                  18. Repeat steps 8, 9, and 10 again.
                  19. Select [Boot Rom].
                  20. Tap [Start] to update the Boot ROM.
                  21. Repeat step 8 (enter firmware mode once more).
                  22. Install the latest firmware.
                  23. Reboot the device after flashing.
                  #### Final Steps:
                  - After booting, the MFP will display a [Recovery Data] error → Press [Yes].
                  - Once recovery completes, the system will prompt a restart.
                  DONE!
                  ce password to default
                  • Boyaka1989
                    • Mar 2021
                    • 19
                    #24
                    #### Preparation:
                    10.
                    #### Final Steps:
                    DONE!
                    i treid this but after bootrom the display did not tun on i hear the machine running but thats it
                    • stronghold
                      • Apr 2023
                      • 47
                      #25
                      Hi. You have a trouble with SPI FLASH on CPUBoard. Look THIS POST
                      Greetings to everyone on this forum. I want to share a significant observation about i-series. Based on my repair experience, I have currently restored CPUB boards from various models with different i-series symptoms. I can confidently state that 90% of unexplained problems are related specifically to this board. Symptoms:
