We have not had much CPU board issues more SD card issues and a $8 SD card from Walmart fixes that. The extra setup is not normal for sure and can add a unplanned cost on a mechine that does not have much profibilty with toner cost alone if you want to keep it competitive with other brands.
What are you selling instead of C3320i/C3321i ?
We have started selling the HP M577 (e57540) we have had decent luck with these. I have never been a fan of the Kyocera A4 machines. The Kyocera A4 design has been around for a while. It's a PITA when you have to change anything other than the tonerComment
Roughly 70% of the machines that required a new SD card in their service life reported SPI Flash failure using the diagnostic FW tool provided by KM.
I also reccomend not using cheapo SD cards as their read/write cycles are terrible, as always do what works for you. I had a 6quid one from amazon fail within 2 days, I only ever use SanDisk ones from now on.👍 1Comment
Can't argue with that at all. Got to pull the ITB to get to the drums/devs and the fuser replacement sucks comapred to KM. The ITB is a pain on the 3320i too though. Basically all A4s suck in some way. If I could, I would just give everyone an A3.Comment
