Konica minolta 454 and 364
  • iraklis7302
    • Jan 2022
    • 54
    HELLO SIR!!,
    my machines have 2 problems and i dont know what it is.First my 454 has faded colors on the lower at the page as you can see in my photo.
    and my second machine 364 has small angle lines only at my magenta color almost on every part on page as you can see in my photo.
    thank you all in advance
  • Konicatech
    • Feb 2016
    • 131
    Re: Konica minolta 454 and 364
    Hi
    Your magenta dev unit needs to be replaced.
    • iraklis7302
      • Jan 2022
      • 54
      Originally posted by Konicatech
      Hi
      Hi, i have allready replaced it with a new one last week
      • xerotec
        • Oct 2009
        • 45
        Originally posted by iraklis7302
        HELLO SIR!!,
        On the first 454 machine clean mirrors of polygon motor on laser unit, on second is magenta dev unit.
        • iraklis7302
          • Jan 2022
          • 54
          ok thank you so much!i will do it
            • 22963
            What do these images look like?:
            • tsbservice
              Field tech
              • 7929
              +1
              • iraklis7302
                • Jan 2022
                • 54
                these images are good in my 454,i found that the problem is when i print double sided.only my first side is good
                • iraklis7302
                  • Jan 2022
                  • 54
                  Hi
                  probably my high voltage unit board need to be replaced.th developer was changed last week,but because of high voltage board ,the dev unit was damaged
                  • kingarthur
                    • 1305
                    are there any units "beyond life" especially drums, if you don't replace them, you'll just keep replacing the dev unit
                      • 22963
                      Just out of curiosity, have you tried fresh paper? High humidity in the paper can cause poor transfer ... but it's the first side that comes out faint. The fuser dries the paper somewhat, making the second side look better. =^..^=
