Develop 450i Function Code For Airprint 2.1
  • copytechtrouble
    • Nov 2020
    • 95
    [Misc] Develop 450i Function Code For Airprint 2.1
    Hello,
    I have a develop ineo+ 450i, i have updated to the latest firmware version KJ.
    When trying to activate Airprint 2.1 with the function code K9WVG9TXQ8F6D9TRWWPVWYD4M4M8QVC6. I get an error that says, "Failed to Enable. Check the Function Code."
    I have also tried the function codes for Konica and Olivetti machines and get the same error.
    I cant find anything relating to this issue on the KNova or Olivetti sites. has anyone else encountered this issue?
  • Synthohol
    Certified Konica Expert
    • 5799
    Re: Develop 450i Function Code For Airprint 2.1
    Dww3pvrrrtd3kxppwxm8dxkrj6rpcqqv
    • Gift
      • Mar 2011
      • 2458
        • 22997
        Originally posted by Gift
        [ATTACH=CONFIG]51678[/ATTACH]
        Yeah, I get a lot of unsolicited help with my typing. =^..^=
        • emujo2
          • Mar 2017
          • 1580
          Air print is a network protocol, it does not need to be enabled with any kind of function code. What you have is a license code for an LK of some sort. Air print is available out of the box, but might need to be enabled at the PSWC level. E
          • copyrooks
            • Oct 2013
            • 209
            You might need to change your software switch 25 to hex 20
            There's an known issue from konica related to that.
            • copytechtrouble
              • Nov 2020
              • 95
              Airprint needs to be re-enabled with a function code when the latest firmware (KJ) is installed.
              Apple have changed the security settings relating to Airprint and the machines need the new function code installed in order to get Airprint to work.
              • copytechtrouble
                • Nov 2020
                • 95
                Update and FYI,
                I got it to work with this function code,
                KVX4RPQ7G7FQQRQPC3F6XRWYM2G3TXVV
                thank you kind stranger.
                Originally posted by copytechtrouble
                Hello,
                [ATTACH=CONFIG]51676[/ATTACH][ATTACH=CONFIG]51676[/ATTACH]
                • Synthohol
                  • 5799
                  LOL@keyboard cat!
                  this is my source
                  Error
                  AirPrint is not available with firmware version G00-29 ( bizhub C650i/C550i) G00-79 (bizhub C450i) function version 2.0.
                  Root Cause
                  Airprint Activation code has not been entered
                  Workaround/Fix
                  New firmware will be released addressing this issue. Until new firmware is made available, please enter the function codes listed below for the corresponding MFP to activate AirPrint.
                  Model Function Code
                  bizhub C360i/C300i/C250i J7TRH7GTBYVRPWJWD3K7GPPYBTGXHVWR
                  bizhub C4050i/C3350i MPGQW6J2GTXWJ2X3BPXRRXP4PPJXQMH7
                  bizhub C3320i TPB8CTBPKTQ2J3HPRMQ7MMT8RXTYMMVT
                  bizhub C4000i/C3300i TPB8CTBPKTQ2J3HPRMQ7MMT8RXTYMMVT
                  bizhub 306i/266i/246i/226i VYRRH8T3XWB2TXB2RPF8VPRXV4CRC6FY
                  bizhub C650i/C550i/C450i DWW3PVRRRTD3KXPPWXM8DXKRJ6RPCQQV
                  also...
                  Problem
                  AirPrint version 2.1 is not available after installing firmware G00-K8 function version 2.2.
                  Solution
                  CAUSE: Certificate is required for Airprint version 2.1
                  SOLUTION: Please refer to the workaround below.
                  1. Downgrade function version for G00-K8 to 2.1 by setting software switch 25 to Hex 20
                  or
                  2. Downgrade firmware version to G00-J9 function version 2.1
                  Note: Once KMI (Konica Minolta Incorporated) obtains the certificate for AirPrint2.1, we will provide activation code to use AirPrint2.1.
                  • occus
                    • 331
                    LOL@keyboard cat!
                    this is my source
                    Error
                    Root Cause
                    Workaround/Fix
                    Model Function Code
                    also...
                    Problem
                    Solution
                    or
                    Update on 19th October 2021
                    KMI has got the certificate for Airprint 2.1
                    It is possible to set Function version 2.2 (HEX 30) with the right license code.
                    • ivovb
                      • 695
                      Procedure that works
                      1. Upgrade to K8.
                      2. SS25 > HEX30. Restart.
                      3. [Utility] > [Administrator] > [Maintenance] > [Authorization function Setting]:[Install License]
                      Now You have AirPrint v2.1 in Network Menu.
                      Another way to confirm AirPrint availability - [Utility] - [Device Information] - [Auth. function list display].
                      BR
                      I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
