km c654e
  • romario
    • Jun 2020
    • 192
    km c654e
    hello group. I have this error in printing, the first impression fails, and the second one goes well, now I cause a paper jam before the machine makes the transfer to the paper and the impression is perfect in the ibt, the fault is when transferring to the paper. I already changed the transfer roller and the fault continues,
    WhatsApp Image 2022-01-27 at 4.44.44 PM.jpgWhatsApp Image 2022-01-27 at 4.44.44 PM(1).jpg
    thanks
  • tsbservice
    Field tech
    • 7990
    Re: km c654e
    Change paper size is it the same. Looks like brush effect try to fine adjust fusing speed in SM.
    • romario
      • Jun 2020
      • 192
      Re: km c654e
      A3 /SRA3 same fault. now the missing toner on the paper. it is in the ibt band, it seems that it did not cover 100% of the toner
      a..
      thanks
      • romario
        • Jun 2020
        • 192
        Re: km c654e
        thanks
          • 22999
          Re: km c654e
          What media type?
          Have you selected the correct media type setting?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4649
            Re: km c654e
            Once again a lot of important information is missing, What is total page count? Transfer belt life count? Using genuine toner & other consumables?
            Almost looks like the transfer belt when you wipe it down with alcohol and it take several pages to clear up. I would focus on the Trans belt.
            • romario
              • Jun 2020
              • 192
              Re: km c654e
              I already changed ibt module. original toner. occate the paper lock before transferring to the paper to verify if the image came from the ibt band defective. but it is not perfect 100%
              thanks
