Fs 537 not working, paper getting stuck in the RU.
  • Ado Mmoloki Moepedi
    • Jan 2022
    • 31
    [Dead] Fs 537 not working, paper getting stuck in the RU.
    I have a bizhub 758 and a 654e. I also have a 537 and another finisher. All this models work with this finisher except for the fs 537, for some reason the paper gets stuck in the RU.
    Hope I can get help.
    • 22966
    Re: Fs 537 not working, paper getting stuck in the RU.
    Jam code?
      • Jan 2022
      • 31
      Jam code?
      This is the situation I have, I'm sorry if my description was vague. I'm trying to do some troubleshooting, another person was assigned to this and left it midway. The only knowledge I possess is that the fs 537 is not working properly. I have a c654e copier working with a fs 536 finisher. The copier which is meant work with the fs 537 is a 758 which is already at the customer site. I tried to connect the fs 537 to the c654e, when I do the Machine gets stuck at the boot screen and blink the alert led. I unplugged the finisher and turned on the machine and tried to connect the finisher with the printer on and it shows that it receives power but when I try to copy. The paper gets stuck in the RU which is not the case when I run the Engine with the fs 536. I don't have a lot of experience in this field but I'm excited to learn.
      NB: if you have the manual I would be grateful if you could send it my way.
      Thank you for your kind response.
      • Synthohol
        Certified Konica Expert
        • 5750
        fs-534 and fs-535 with an ru-513 are the correct finishers for the c654e.
        anything else may start blowing boards.
          • Jan 2022
          • 31
          Thank you for your response. I figured as much when I realized that they is nothing wrong with the RU. In your experience what are the possible issues that could have the finisher not working properly?
          • Synthohol
            • 5750
            Well, plugging it into the wrong model can certainly blow a board or 2.
            I moved a machine once and the finisher got unplugged while it was on but being behind the machine I didn't realize and plugged it back in.
            It blew the ru board and the fns board.
            And that wass on a correct machine
              • 22966
              I learned this lesson a long time ago. The damage happens when you plug in an accessory when the rest of the machine is booted up/live. If the accessory becomes unplugged while live, turn the MFP OFF. Then reconnect the accessory.
              I really can't offer anything useful without a jam or error code. =^..^=
              • Thayer
                • Dec 2017
                • 107
                FS-537/537SD needs a RU-515, which I believe is only for 758/808/958 series. FS-536/536SD also can be ran on those models.
