KM 8 series Manually Install firmware
  • Jinn
    • May 2023
    • 134
    Hi Experts,
    I want to install firmware in 8 series models using the ISW > Download firmware option. Not using the FTP, HTTP, or Proxy. I was checking there is an option "download firmware". Is there any possibility if I prepare USB with firmware in it and plug then go to service mode > ISW> Download firmware?
    Thanks in advance
    Regards,
  • JMS
    • Apr 2023
    • 28
    You want the USB plug into the machine? Then you can update it without ISW.
    Extract the FW00xx-folder to rhe root of the USB. Turn off machine. Plugin the USB. Turn onmachine while pressing the STOP-Key. A black dot appears in one of the upper corners.
    Firmware update screen is dispalyed.
    ISW can only download from a server (ftp, http)
    • Jinn
      • May 2023
      • 134
      Thank you for kind words.
      I am familiar with the firmware update procedure via USB. The problem is the firmware is not upgrading from USB. So I was thinking to use another method. If you can help me by guiding how to update using ISW.
      • Synthohol
        Certified Konica Expert
        • 5849
        its probably your USB. konicas can be really picky.
        or the front usb is plugged into the wrong slot on the MFPB.
        4 gb drives work best if you have one.
        • Dianon
          • Apr 2025
          • 16
          Happen to me sometimes too.
          It always works when i clean the USB drive .
          On Windows use Diskpart:
          1. Open comandline (Win+R and input 'cmd')
          2. input 'diskpart'
          3. input 'list disk'
          4. remmber the correct number for your usb drive
          5. input 'select disk x'. X is the number of your drive in the step before
          6. input 'clean'
          7. input 'create primary'. you could extend it with size=2048 (ex. 'create primary size=2048') when you have a realy big drive. KM has had problems with drives bigger then 4GB
          8. input 'select partition 1'
          9. input 'format fs=fat32 quick'
          10. input 'assign'
          11. after that you could copy the FW to the drive again
          12. in 99% of cases the machine would now except the FW. in the other 1%, either the FW is defect (try to download it again) or the machine has some serious problem
          • FuserNoob
            Service Mgr, CISSP
            • Jul 2022
            • 149
            I've had good luck with these:
            https://www.amazon.com/Drives-Memory...st_sto_dp&th=1
            And they have an LED that blinks when it's being read, so I KNOW they're processing!
            • Jinn
              • May 2023
              • 134
              Actually the problem is "Sata controller firmware " the recovery firmware, Machine is not taking. USB is 8GB. For other firmware it works fine but this one takes a lot of time and no output. It stays at the startup pillars. Error is C-D011
              • WisamM
                • Feb 2023
                • 23
                If you get error C-D011, you need to format the HDD.
                • JMS
                  • Apr 2023
                  • 28
                  Which 8-series machine is the problem machine?
                  Found this technical information, but it's only for C258/C308/C368.
                  • Jinn
                    • May 2023
                    • 134
                    2. input 'diskpart'
                    6. input 'clean'
                    10. input 'assign'
                    When I input "Create primary" I get this error
                    • Jinn
                      • May 2023
                      • 134
                      • doinbox
                        • Jan 2013
                        • 112
                        Originally posted by Jinn
                        It should just be "format fs=fat32 quick" because you already have the disk selected it knows which disk to format
                        • JMS
                          • Apr 2023
                          • 28
                          • Jinn
                            • May 2023
                            • 134
                            Partition created successfully. Now usb is showing 2 GB capacity. But but but reset tool, any firmware, or Sata Firmware not taking at all. I have 2 USBs , made them 2GB but still no success
