Constant white lines throughout printing (horozontal)
  • U12runzn
    • Jan 2022
    • 5
    Konica Minolta C658
    Hi I have the above machine which was just purchased.
    The machine prints with white lines as per photo on test prints
    The transfer belt I was advised is new and OEM.
    The drum units as I was informed are new OEM
    Basically the machine was refurbished . However it prints rubbish with those lines that appears on all CMYK test prints
    What do I look out for to solve this
  • Thayer
    • Dec 2017
    • 107
    Re: Constant white lines throughout printing (horozontal)
    What have you tried??
    • U12runzn
      • Jan 2022
      • 5
      Crying
      • femaster
        • May 2011
        • 1458
        That's a new one to me. On those samples where is the lead edge / direction of feed?
        • Hansoon
          • Sep 2007
          • 3349
          Very hard to judge from the worthless pictures. I have seen similar when making sky shots under a fluorescent tube light.
          Hans
          “ Sent from my Intel 80286 using MS-DOS 2.0 “
          https://www.copytechnet.com/images/smilies/biggrin.png
          • Drivee
            • Nov 2020
            • 322
            Somethin obstruct laser I think.. or peace of paper scratch transfer belt!!! I can be.
            • Gift
              • Mar 2011
              • 2444
              Hans
              +1
              • kingarthur
                • 1301
                Hans
                +2 for me too
                • tsbservice
                  Field tech
                  • 7911
                  He claimed samples are test prints guys. I suppose those lines are parallel with paper feeding direction.
                  Author can you post a picture of ITB when you open side door.
                  • REGSIS
                    • May 2016
                    • 434
                    If not ITB then tranfer roller must be the cause.
                    Fuser wouldn't create such regular pattern.
                    PH unit will not create this on all colours.
                    (This pattern is not common problem for poligonal mirror)
                    Try to stop the printout before fuser. Remove ITB and drum(s) and look for these irregularities.
                    Hope you find it at some point.
                    • Synaux
                      • Mar 2012
                      • 1224
                      Originally posted by U12runzn
                      Crying
                      That made my day!
                      Use your machine to scan in the prints with direction of output!
                      As stated, probably not the PH if on all 4 colors.
                      What are the meter counts?
                      A terrible transfer roller might cause this--especially if in the middle.
                      Remove transfer belt and inspect. (I had something similar when a fuser roller blew up and got stuck on the topside of the belt.)
                      On that note, check the fuser but I would expect a bunch of toner crustys from un-fused toner.
                        • 22932
                        Crying
                        Did it help? =^..^=
