glad you are making progress, did you select LPD port 515 and Print as the Queue name?
sometimes even a 1mm or 16th of an inch of the adjustment makes a difference in those VR sensors.
also command workstation allows you to transfer over the whole file and let the Fiery rip and spool it and add finishing options if wanted.
much faster than spooling on the local HDD.
there may be an option in the driver to NOT spool jobs on the local HDD, been a while since i saw MAC print properties windows!
